KarenB36
Help.......cannot get my issue resolved
I have really bad broadband speed, followed all the tips etc and guidance online. Lost the broadband completely and out of the blue Virgin called and sent me a free of charge booster. Installed and made the connection a lot worse, 10mb speed ! I pay for 100mb.  I called Virgin support waited 3.5 hours and they said they could see the booster working but I had it unplugged !  They sent me another booster as they said the ones I had must be faulty and then charged me for them !  Still made the connection worse and I was advised that the booster sent was incompatible with my router. Went on chat for 19 hours and they ended the chat without speaking to me...…. I called again and got cut off..... finally raised a complaint, and after 4 weeks was contacted,  I was promised and engineer and a new contract to be set up, I have been a customer since 2012 and they promised to call me back if they cut me off...… cut me off and no call back, complaint was closed !!  Raised another compliant and stopped my direct debit,  I was being charged an incorrect charge by this point and after another few weeks called me,  promised to call back if I was cut off and arrange an engineer...… cut me off and no call back.  All I want is an engineer to fix the speed,  supply compatible boosters, set up a new contract and charge me for the right service.  Unfortunately I cannot go anywhere else as other providers do not supply to my area which isn't rural !   Can anyone help !
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Help.......cannot get my issue resolved
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
