swirve
  • 28
Message 1 of 5
Having problems with Internet dropping on a daily basis
As subject, my Internet cuts out several times a day, typically at similar times and in particular the upload speed drops to nearly 0, even though nothing is being uploaded. The router wifi disconnects also.
Cable Modem Status
Item
Status
Comments
298750000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
Refresh data
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
298750000
-1.5
40
256 qam
21
2
234750000
-1
40
256 qam
13
3
242750000
-1
40
256 qam
14
4
250750000
-1
40
256 qam
15
5
258750000
-1
40
256 qam
16
6
266750000
-1.2
40
256 qam
17
7
274750000
-1.2
40
256 qam
18
8
282750000
-1.2
40
256 qam
19
9
290750000
-1.2
40
256 qam
20
10
306750000
-1.7
40
256 qam
22
11
314750000
-1.4
40
256 qam
23
12
322750000
-1.7
40
256 qam
24
13
330750000
-1.7
40
256 qam
25
14
394750000
-1.7
40
256 qam
26
15
402750000
-1.7
40
256 qam
27
16
410750000
-1.4
40
256 qam
28
17
418750000
-1.7
40
256 qam
29
18
426750000
-1.5
40
256 qam
30
19
434750000
-1.7
40
256 qam
31
20
442750000
-1.5
40
256 qam
32
21
450750000
-1.9
40
256 qam
33
22
458750000
-1.4
40
256 qam
34
23
466750000
-1.5
40
256 qam
35
24
474750000
-1.4
40
256 qam
36
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
6
0
2
Locked
40.3
0
0
3
Locked
40.3
6
0
4
Locked
40.9
0
0
5
Locked
40.9
5
0
6
Locked
40.3
0
0
7
Locked
40.3
5
0
8
Locked
40.3
5
0
9
Locked
40.3
5
0
10
Locked
40.3
0
0
11
Locked
40.3
6
0
12
Locked
40.3
0
0
13
Locked
40.3
5
0
14
Locked
40.9
5
0
15
Locked
40.3
6
0
16
Locked
40.3
6
0
17
Locked
40.3
0
0
18
Locked
40.3
5
0
19
Locked
40.3
0
0
20
Locked
40.9
5
0
21
Locked
40.3
0
0
22
Locked
40.3
0
0
23
Locked
40.3
4
0
24
Locked
40.3
0
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
42.5
5120
64 qam
10
2
46200000
42.8
5120
64 qam
9
3
60300000
43.5
5120
64 qam
7
4
53700000
43
5120
64 qam
8
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
swirve
  • 28
Message 2 of 5
Re: Having problems with Internet dropping on a daily basis
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID
33138
Max Traffic Rate
117000047
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
33137
Max Traffic Rate
10500047
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
Time
Priority
Description
09/12/2020 10:36:39
critical
06/12/2020 13:13:33
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 21:03:16
critical
03/12/2020 01:13:33
Error
03/12/2020 00:39:31
critical
03/12/2020 00:38:48
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 00:33:33
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 00:33:29
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 00:33:29
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 00:33:29
Warning!
03/12/2020 00:33:28
critical
03/12/2020 00:33:28
Warning!
02/12/2020 19:51:34
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 17:54:32
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2020 19:52:2
critical
27/11/2020 18:45:39
Error
27/11/2020 17:59:57
Error
27/11/2020 17:40:54
critical
26/11/2020 18:25:0
Error
23/11/2020 13:57:2
critical
swirve
  • 28
Message 3 of 5
This network log does not show that between 7pm and 9pm 9/12/20 the router disconnected me three times from the wifi, all connections to it and the router was flashing green light.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 5
swirve
  • 28
Message 5 of 5
My BQM
