Hard wired speeds
jc8ond
If my pc is hardwired via the Virgin Media WiFi extenders Ethernet port, will the speed be lower than stated fastest speed, I am currently getting just over 100mbps hard wired via WiFi extender Ethernet connection and over 200mbps with WiFi near the hub downstairs, I am currently on the M500 package
2 REPLIES 2
carl_pearce
Trouble shooter
Hard wired into an extender still means using WiFi so yes, lower speeds are expected, depending on the distance from the HUB.
Chris_W1
Hi jc8ond, thanks for the message and welcome back to the forums.
I am sorry to hear that there was a connection issue but we have looked into this and can see no issues with the speed or the area.
Can you do a wired speed test directly to the hub and let us know the results? ^Chris
