woppy101
  • 28
Message 1 of 7
Half speed again, this is becoming a joke
At least once every 2-3 weeks my download speed drops in half, it’s now becoming a joke, I have done all the housekeeping ie updating software, restarting routers, this is now a joke, it wouldn’t be so bad I’d I was on a good deal for my 350mb, but at £45pm it’s a joke.
as normal here are my stats
253310000008.739QAM25625
323870000007.740.4QAM25632
333950000007.639QAM25633
34403000000839QAM25634
354110000008.140.4QAM25635
364190000007.840.4QAM25636
61790000007.439QAM2566
71870000007.539QAM2567
81950000007.439QAM2568
92030000007.339QAM2569
102110000007.240.4QAM25610
112190000006.939QAM25611
122270000006.538.6QAM25612
132350000006.239QAM25613
142430000006.239QAM25614
152510000006.339QAM25615
162590000006.839QAM25616
172670000007.440.4QAM25617
182750000007.640.4QAM25618
192830000007.739QAM25619
202910000008.139QAM25620
212990000008.139QAM25621
223070000008.239QAM25622
233150000008.739QAM25623
243230000009.139QAM25624
263390000008.439QAM25626
273470000008.340.9QAM25627
283550000007.939QAM25628
293630000007.539QAM25629
303710000007.639QAM25630
31379000000840.4QAM25631
3.0 Downstream channels
25Locked38.98326100
32Locked40.36628700
33Locked38.98326100
34Locked38.98326100
35Locked40.36628700
36Locked40.36628700
6Locked38.98326100
7Locked38.98326100
8Locked38.98326100
9Locked38.98326100
10Locked40.36628700
11Locked38.98326100
12Locked38.60537700
13Locked38.98326100
14Locked38.98326100
15Locked38.98326100
16Locked38.98326100
17Locked40.36628700
18Locked40.36628700
19Locked38.98326100
20Locked38.98326100
21Locked38.98326100
22Locked38.98326100
23Locked38.98326100
24Locked38.98326100
26Locked38.98326100
27Locked40.94620900
28Locked38.98326100
29Locked38.98326100
30Locked38.98326100
31Locked40.36628700
3.1 Downstream channels
159964K1880QAM4096759
159Locked416.680115340
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/974bd7d94e4d06051b19031ead5050f1068804f9"><img alt="My Broadband Ping - Woppy" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/974bd7d94e4d06051b19031ead5050f1068804f9.png" /></a>
jb66
  • 13.01K
  • 991
  • 1.95K
Message 2 of 7
Re: Half speed again, this is becoming a joke
Hub3 or 4?
Andrew-G
  • 11.17K
  • 1.73K
  • 5.34K
Message 3 of 7
As it's got a D3.1 channel it has to be a Hub 4 or 5, and the presentation of hub stats suggests a Hub 4.
Looking at the BQM there's an intermittent fault that isn't demonstrated by the hub stats, I'm guessing a physical damage or connection fault for the coax.  I'd wait for forum staff to take a look - it'll probably need a technician visit, and might need more than one because intermittent faults are a real pain to detect, although the tech may get lucky if it's simply a connection that needs remaking.
jb66
  • 13.01K
  • 991
  • 1.95K
Message 4 of 7
There is a massive thread about hub4s ethernet ports going from 1000mb to 100mb, perhaps it's that
woppy101
  • 28
Message 5 of 7
I am in modem mode and use a router, worth a try though do you have a link.
edit now lucky to break 100meg, sometimes touches 120/30.
jb66
  • 13.01K
  • 991
  • 1.95K
Message 6 of 7
Martin_N
  • 8.87K
  • 371
  • 536
Message 7 of 7
Hi woppy101,
Thank you for your post. I'm very sorry to hear about the broadband speed issue you've been having.
I have taken a look on our system and I am unable to see anything that could be affecting this.
What I will need to do is private message you to confirm some details and then we can proceed with further checks.
^Martin
