muffintastic
  • 81
Dialled in
Message 1 of 25
Half The Speed of M200
Hello i'm posting on behalf of my mom.
She is on the M200 package however she is only getting between 80-100 MB on speedtests. Could someone take a look at the router log and see if it's in good spec?
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
291000000
0
38
256 qam
20
2
139000000
-0.4
38
256 qam
1
3
147000000
0
38
256 qam
2
4
155000000
0
38
256 qam
3
5
163000000
0
38
256 qam
4
6
171000000
0
38
256 qam
5
7
179000000
0
38
256 qam
6
8
187000000
0
38
256 qam
7
9
195000000
0
38
256 qam
8
10
203000000
-0.2
38
256 qam
9
11
211000000
-0.2
38
256 qam
10
12
219000000
-0.5
38
256 qam
11
13
227000000
-0.7
38
256 qam
12
14
235000000
-0.7
38
256 qam
13
15
243000000
-1
38
256 qam
14
16
251000000
-1
38
256 qam
15
17
259000000
-1.2
38
256 qam
16
18
267000000
-0.9
38
256 qam
17
19
275000000
-0.9
38
256 qam
18
20
283000000
-0.2
38
256 qam
19
21
299000000
0.2
38
256 qam
21
22
307000000
0.2
38
256 qam
22
23
315000000
0.2
38
256 qam
23
24
323000000
0
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
937
170
2
Locked
38.6
608508
392187
3
Locked
38.6
106968
330728
4
Locked
38.9
544116
415437
5
Locked
38.6
626655
745461
6
Locked
38.9
71834
448163
7
Locked
38.9
1799757
1423250
8
Locked
38.9
1888319
77547
9
Locked
38.9
1141
276
10
Locked
38.9
1035
204
11
Locked
38.6
922
196
12
Locked
38.9
869
212
13
Locked
38.9
971
230
14
Locked
38.6
1320
280
15
Locked
38.6
1784
312
16
Locked
38.9
2139
283
17
Locked
38.6
1826
260
18
Locked
38.9
1550
271
19
Locked
38.6
1104
238
20
Locked
38.6
941
191
21
Locked
38.6
972
124
22
Locked
38.6
781
113
23
Locked
38.6
665
63
24
Locked
38.9
565
71
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400039
4.55
5120
64 qam
4
2
46200000
4.65
5120
64 qam
3
3
53700036
4.7
5120
64 qam
2
4
60300061
4.85
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
34ncxv9873254k;fg87dsfd;kfoA,.
SFID
20182
Max Traffic Rate
230000061
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
19983
Max Traffic Rate
22000061
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
  • 5.69K
  • 912
  • 1.34K
Hero
Message 2 of 25
Re: Half The Speed of M200
Hi muffintastic,
Are the speed tests being performed using an ethernet cable or by wifi using a PC?  VM don't guarantee the wifi speed.
The speed may also be restricted by the network card, is it capable of higher then 100MB? This is often the problem with older devices.
Dave
muffintastic
  • 81
Dialled in
Message 3 of 25
Tests are being performed via cat6 ethernet cable, gigabit port and nothing connected to the main router, however for some reason it's rectified itself. I would like a confirmation the specs are in reasonable range.
Z92
  • 2.26K
  • 187
  • 350
Problem sorter
Message 4 of 25
Your specs don't look too bad, but I'd be concerned about the amount of errors on the line, I'd try a reboot to clear them and if the problems appear again have another look at them.
muffintastic
  • 81
Dialled in
Message 5 of 25
I did do a reboot last night, been up for a few hours.
muffintastic
  • 81
Dialled in
Message 6 of 25
*bump*
No good, problem just returned, back down to 60-80. God knows what the issue is.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 25
muffintastic
  • 81
Dialled in
Message 8 of 25
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3f28fb97451216f3e7d7d6d6c33f269ed0...
I forgot to mention i am running an external router; RT-AC3200 [Asus] running on the Merlin firmware. What i'll try and do reset the Virgin router and Asus and change the WAN ethernet cable. It maybe a faulty ethernet cable to be honest, not sure, the upload seems fine, when i rum a test sometimes i get the full 200 (219) then it'll drop down and vice versa. .
RayMRQ
Message 9 of 25
Just to note, your not alone, my speed just got halved couple hours ago and not been able to get it back up to normal speeds, also in modem mode+restarted router & modem and still got the same speed, area reference 21.
Am curious as to why it would just throttled? Had VM close to 2 years now. and haven't had an issue like that ever.
muffintastic
  • 81
Dialled in
Message 10 of 25
Variable results from internal speedtest Asus (WAN) <> Router (Modem Mode)
