Oneale90
  • 6
Message 1 of 10
Half Of Advertised Speed (91mbps on 200mb connection)
Good morning all.
 Towards the start of the year, I changed my subscription to be Broadband only and for the 200mb line speed. Since changing I cannot get over 95mbps download speed. The connection itself is stable but much slower (over 50%) than I was expecting. Just wondering if anyone has any ideas as to why?
 I'm currently on a Hub 3.0 in Modem mode and all data and speeds are taken from a direct ethernet connection via a network card.
Any help would be appreciated.
 Regards, Josh
1394000084.275512064 qam4
2462000204.3512064 qam3
3603000764.4512064 qam1
4537000184.35512064 qam2
3ATDMA0000
4ATDMA0000
1595000000-0.436256 qam24
2475000000137256 qam9
34830000000.937256 qam10
4491000000137256 qam11
54990000000.537256 qam12
65070000000.737256 qam13
75150000000.737256 qam14
85230000000.737256 qam15
95310000000.237256 qam16
10539000000037256 qam17
11547000000-0.436256 qam18
12555000000-0.736256 qam19
13563000000-0.736256 qam20
14571000000-1.236256 qam21
15579000000-0.536256 qam22
16587000000-0.536256 qam23
17635000000-235256 qam25
18643000000-2.235256 qam26
19651000000-236256 qam27
20659000000-2.535256 qam28
21667000000-2.535256 qam29
22675000000-2.735256 qam30
23683000000-3.435256 qam31
24691000000-3.735256 qam32
1Locked36.333080
2Locked37.35230
3Locked37.34950
4Locked37.65980
5Locked37.36860
6Locked37.36110
7Locked37.36990
8Locked37.37950
9Locked37.69770
10Locked37.610570
11Locked36.317500
12Locked36.616330
13Locked36.617110
14Locked36.619530
15Locked36.623020
16Locked36.328680
17Locked35.799570
18Locked35.7109500
19Locked36.3111690
20Locked35.5139700
21Locked35.7157830
22Locked35.7232460
23Locked35.7217670
24Locked35.7270740
Anonymous
Not applicable
Message 2 of 10
Re: Half Of Advertised Speed (91mbps on 200mb connection)
looks like what you would see with a 100mbps network card or router.
What router and network card are you using
Oneale90
  • 6
Message 3 of 10
Hi Apcyberax,
 Thanks for the quick reply.
 My current home setup is the Hub 3.0 which feeds 2 x Asus RT-AC51U Routers. My Tower is then hardwired into the router via a Realtek 8111H Gigabit LAN Controller (Motherboard mounted connectors, not PCI-e expansion.
 Are you suggesting the Routers could be throttling the connection speed ?
Anonymous
Not applicable
Message 4 of 10
why 2 routers?
is the hub in modem mode?
Oneale90
  • 6
Message 5 of 10
Sorry, I should have explained the network a tad better.
 The Hub and router 1 are upstairs in the network cupboard (Fixed Cat 6 throughout the house) and it’s Router 1 I connect to via Ethernet.
Router 2 is set as a WiFi receiver and simply boosts the signal around the downstairs portion of the house.
Hub is in modem mode and connected to the Router via port 4 (which from memory is correct?)
 Regards,
Anonymous
Not applicable
Message 6 of 10
the other things that can limit speed down to 100 is damage or cheap network cables.
Have you tested with a new cable
Oneale90
  • 6
Message 7 of 10
Now that you mention it, I may have a crossover cable being used as a networking cable... This will obviously limit the connection speed!
 I'll give this a shot and let you know what the results are!
 Many thanks
 Josh
Oneale90
  • 6
Message 8 of 10
Just checked,
 All straight-through cables, so no problems there.
 Still left scratching my head as to what it could be ...
gary_dexter
  • 30.4K
  • 1.88K
  • 4.04K
Message 9 of 10
What speed do you get wired direct to the hub without the routers?
Oneale90
  • 6
Message 10 of 10
It turns out it was the router. Although it was listed as a Gigabit router, for some reason you have to set this in its OIS.
 All sorted and now pulling 200+ Mbps.
 Thanks for all your help guys
 Josh
