jessemooreuk
  • 5
Message 1 of 7
HELP - Trying to support NHS Trusts and I have near constant packet loss
I'm struggling to support various NHS Trust's IT for the last 5 days or so. VPN drops, website timeouts etc.
The VM service checker keeps throwing back an error saying the tests failed. As in it can't run the tests.
I've stuck my VM Hub into Modem Mode, and put my trusty Cisco Hardware (ex Cisco) in front of it. So I've got better control and visibility into whats going on.
This is the outside interface attached to port one of the Virgin Media Hub. Which runs a test to Google DNS.
Obviously I've tried cold starting the VM Hub, and checked cables with no effect. It's not my hardware as this issue started days before I put my Hub into Modem Mode. This is just for fault testing.
I really need help because I'm reliant on at this time to help them out.
Jesse
jessemooreuk
  • 5
Message 2 of 7
Re: HELP - Trying to support NHS Trusts and I have near constant packet loss
Image not showing so I've popped it here: https://ibb.co/Km8JcHL
Stumac1980
  • 130
  • 25
  • 25
Message 3 of 7
Please PM me with your account number and area reference and I can take a look at this for you.
Stuart
I am a Virgin Field Technician. All and any advice given is based on my experience in the field or my personal experiences with my own set up at home. If my answer was helpful to you please mark as helpful or consider leaving the post some kudos.
jessemooreuk
  • 5
Message 4 of 7
Thank you, pm'ing shortly!
jessemooreuk
  • 5
Message 5 of 7
I have pm'd
ToffeeSurprise
  • 181
  • 11
  • 32
Superfast
Message 6 of 7
You able to post the output from your hub so people can see the power levels, SNR, errors etc?
jessemooreuk
  • 5
Message 7 of 7
Item Status Comments
483000000
Locked
Ranged Upstream Channel (Hz)
32600000
Locked
Provisioning State
Online
1483000000-0.937256 qam30
21870000002.738256 qam7
31950000002.738256 qam8
42030000002.438256 qam9
52110000002.438256 qam10
6219000000238256 qam11
72270000002.238256 qam12
8235000000238256 qam13
92430000001.738256 qam14
102510000001.538256 qam15
11259000000138256 qam16
12267000000138256 qam17
132750000000.738256 qam18
14283000000138256 qam19
15291000000138256 qam20
162990000001.238256 qam21
17307000000138256 qam22
183150000000.738256 qam23
193230000000.537256 qam24
20443000000-0.537256 qam25
21451000000-0.736256 qam26
22459000000-0.736256 qam27
23467000000-0.736256 qam28
24475000000-0.737256 qam29
1Locked37.33940
2Locked38.9250
3Locked38.9170
4Locked38.6220
5Locked38.9310
6Locked38.6220
7Locked38.6210
8Locked38.6290
9Locked38.6210
10Locked38.9350
11Locked38.6300
12Locked38.6390
13Locked38.9360
14Locked38.6480
15Locked38.9380
16Locked38.6640
17Locked38.9670
18Locked38.6870
19Locked37.3840
20Locked37.36350
21Locked36.618260
22Locked36.614390
23Locked36.618460
24Locked37.39260
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsl10016u+voc-b.cm
SFID264182
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID264181
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
