TallGuy
  • 6
Message 1 of 10
Good download speed, terrible upload speed
When doing a speed test on my M100 broadband connection, download speed is 100Mbps, upload speeds however are around 0.20 Mbps.
When testing my M100 broadband connection, I get this reponse: "Network issue. We have detected an issue on our network which maybe affecting your broadband service."
I restarted the router and did check all the cables in the house and they all seemed fine. The fact that the download speed is as it should be makes me suspect it's not the cables anyway.
TallGuy
  • 6
Message 2 of 10
Re: Good download speed, terrible upload speed
Huh, after days of terrible upload speeds (and a few hours after I posted this), things are back to where they should be, around 8Mbps. I guess that means the problem is solved for now.
TallGuy
  • 6
Message 3 of 10
Never mind. Speeds are terrible again. This is not going away anytime soon it seems. Upload speeds are as they should be at times and then drop to 0.07 Mbps like this evening. That's two orders of magnitude below what it should be.
Molly_G
  • 421
  • 23
  • 53
Message 4 of 10
Hi @TallGuy,
Welcome to the forums and many thanks for your posts so far. I'm very sorry to hear of the poor upload speeds you have been receiving.
I've just taken a quick look into the account using the details you registered for forums with and can see that there has been ongoing engineering work in your area for the last week to fix an SNR outage (Signal to Noise Ratio). This type of issue can affect your service in many ways and is very likely to be causing the poor upload speeds you've been seeing.
The fault reference number is F008945155.
The good news is, the estimated fix time of the work is 16:00 today.
I'd advise you to monitor your speeds following this time, and it may help to give your equipment a reboot too following the work. Hopefully you will see some improvement and if not, feel free to drop back and we can investigate further.
Many thanks,
Molly_G
TallGuy
  • 6
Message 5 of 10
Thanks @Molly_G , I'll keep an eye out for that
Molly_G
  • 421
  • 23
  • 53
Message 6 of 10
No problem @TallGuy, keep us posted 🙂
Molly_G
TallGuy
  • 6
Message 7 of 10
So far, no luck. I'm still getting upload speeds of about 0.08 Mbps using Speednet. Download speeds are not quite hitting 100 Mbps, looking at 82 Mbps at the moment.
I tried watching a movie on Film4 yesterday and had to stop as the buffering would kick in every 10-15 seconds.
Just posting this response is taking forever as the whole page is completely unresponsive.
Corey_C
  • 3.46K
  • 187
  • 273
Message 8 of 10
Sorry to hear this is still ongoing, TallGuy, however I have checked on the ticket reference, which is for capacity issues, and the ETA is currently set to: 11 MAY 2021 10:00
Corey C
TallGuy
  • 6
Message 9 of 10
The last few days, upload speeds have been mostly good, with the occasional drop down to something like 6Mbps. I didn't want to post too early in case it was a fluke. But for now, things are OK. Fingers crossed.
Corey_C
  • 3.46K
  • 187
  • 273
Message 10 of 10
Thanks for your reply and update, TallGuy.
Cheers,
Corey C
