MarkinLondon
  • 18
Message 1 of 31
Gig1Fibre slow upload speed
I recently upgraded from a 350Mb/s service to Gig1Fibre.  My download speeds seem ok, varying between 600 and 900Gb/s but upload speeds have deteriorated.  Via Speedtest.net upload speeds vary between 2.5Gb/s and about 24Gb/s, and is recently is often in single figures.
On the previous service my upload speeds usually measured 25 to 40 Mb/s.
Since I am video conferencing from home much more these days the upload speed has become more important.  BTW, I have restarted my hub several times, including after the Virgin Media diagnostics told me that would fix a problem it had detected.  Sadly teh recommended restarts made no difference.
Is anyone else experiencing this?  Does anyone have any insights into what can be done to fix it?
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 31
Re: Gig1Fibre slow upload speed
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 31
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 31
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
MarkinLondon
  • 18
Message 5 of 31
Router Status - Downstream
ChannelFrequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
304027500008.30000338.605377QAM25630
113875000011.19999740.946209QAM2561
214675000011.00000040.946209QAM2562
315475000011.09999840.946209QAM2563
416275000011.19999740.366287QAM2564
517075000010.90000240.946209QAM2565
617875000011.00000040.946209QAM2566
718675000010.59999840.366287QAM2567
819475000010.69999740.946209QAM2568
920275000010.59999840.366287QAM2569
1021075000011.00000040.946209QAM25610
1121875000010.80000340.946209QAM25611
1222675000011.00000040.366287QAM25612
1323475000010.90000240.366287QAM25613
1424275000011.00000040.946209QAM25614
1525075000010.69999740.946209QAM25615
1625875000011.09999840.366287QAM25616
1726675000010.80000340.366287QAM25617
1827475000010.50000040.946209QAM25618
192827500009.90000240.946209QAM25619
202907500009.90000240.946209QAM25620
2129875000010.00000040.366287QAM25621
2230675000010.59999840.366287QAM25622
2331475000010.40000240.946209QAM25623
2432275000010.50000040.366287QAM25624
253307500009.59999840.366287QAM25625
263707500009.40000238.983261QAM25626
273787500008.80000338.983261QAM25627
283867500008.80000340.366287QAM25628
293947500008.59999838.983261QAM25629
314107500008.59999838.983261QAM25631
3.0 Downstream channels
30Locked000
1Locked4350737600
2Locked4252779800
3Locked4249005000
4Locked4300903900
5Locked4204804900
6Locked4311831500
7Locked12962604500
8Locked14295680800
9Locked2979080300
10Locked3099502700
11Locked3076357100
12Locked2209893000
13Locked3087934400
14Locked3033131200
15Locked2919156500
16Locked11854634000
17Locked3123262300
18Locked3228852800
19Locked3144692100
20Locked3146962100
21Locked3187134800
22Locked3123872900
23Locked3007891100
24Locked3559431300
25Locked3608840500
26Locked3533436200
27Locked3485680500
28Locked3541818400
29Locked3549212000
31Locked3603932000
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33864K1680QAM4096424
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33Locked 8.95835560
MarkinLondon
  • 18
Message 6 of 31
Router Status - Upstream
3.0 Upstream channels
15370000038.2705995120 KSym/sec64QAM2
23940000038.0205995120 KSym/sec64QAM4
34620000038.2705995120 KSym/sec64QAM3
42580000037.2705995120 KSym/sec8QAM6
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
MarkinLondon
  • 18
Message 7 of 31
Router Status - Configuration
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076+voc-b.cm
SFID
397892
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
397891
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
MarkinLondon
  • 18
Message 8 of 31
Router Status - NetworkLog
Thu 01/01/1970 00:01:513No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:03:535B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:03:543No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 26/05/2020 16:51:335MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 26/05/2020 16:51:334Improper Configuration File CVC Format
Tue 26/05/2020 16:51:434DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 26/05/2020 16:55:423SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:193No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 09:09:245MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 09:12:216SW Download INIT - Via Config file cmreg-vmdg640-bbt076-b.cm
Wed 11/11/2020 09:13:366SW download Successful - Via Config file
Wed 11/11/2020 09:16:095MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 09:44:465MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 09:44:575RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 09:45:106CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 10:41:524DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:183No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 11:05:165MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 11:08:185RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 11:08:306CM-STATUS message sent. Event Type Code: 4; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 11:36:274DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 13/11/2020 03:29:233No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 23:36:284DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 15/11/2020 12:53:433No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 18/11/2020 11:36:284DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 19/11/2020 16:15:493No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 21/11/2020 23:36:284DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 25/11/2020 12:08:473No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 28/11/2020 23:36:294DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 30/11/2020 14:02:445MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 30/11/2020 15:19:175RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 30/11/2020 15:19:466CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 31
31
A lot of your Downstream Power levels are too high.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Anonymous
Not applicable
Message 10 of 31
Just to add to Mike's response one of your upstream channels is out of spec on QAM, which could be caused by noise on the line, which is probably another reason for the slow upload:
