adrianday46
  • 11
Message 1 of 32
Gig1 upgrade slow speed
Just upgraded to Gig1, but only getting 400 to 500Mb. Looked in network status and says no Docsis 3.1 channels. Shouldn’t there be 3.1 channels to get Gig1? Tried to explain on the phone, but they were not very helpful.
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
32
4
DOCSIS 3.1 channels
0
0
  • 32.22K
  • 3.17K
  • 6.12K
Message 2 of 32
Re: Gig1 upgrade slow speed
Yes
Have you tried pinhole resetting the Hub to see if it kicks it into life.
Can you then post up all the stats
adrianday46
  • 11
Message 3 of 32
Unfortunately, after the pinhole reset there are still 0 docsis 3.1 channels.
3.0 Downstream channels
25330750000-5.838.6QAM25625
1138750000-0.840.4QAM2561
2146750000-0.239QAM2562
3154750000039QAM2563
4162750000-1.140.4QAM2564
5170750000-0.440.9QAM2565
6178750000-139QAM2566
7186750000-1.440.4QAM2567
8194750000-1.540.4QAM2568
9202750000-2.339QAM2569
10210750000-3.339QAM25610
11218750000-2.740.4QAM25611
12226750000-3.739QAM25612
13234750000-4.438.6QAM25613
14242750000-3.339QAM25614
15250750000-3.439QAM25615
16258750000-4.239QAM25616
17266750000-3.939QAM25617
18274750000-4.439QAM25618
19282750000-4.839QAM25619
20290750000-4.938.6QAM25620
21298750000-538.6QAM25621
22306750000-638.6QAM25622
23314750000-538.6QAM25623
24322750000-538.6QAM25624
26338750000-5.938.6QAM25626
27346750000-638.6QAM25627
28354750000-6.637.6QAM25628
29362750000-6.137.6QAM25629
30370750000-6.137.6QAM25630
31378750000-8.337.4QAM25631
32386750000-7.637.6QAM25632
25Locked38.60537700
1Locked40.3662875600
2Locked38.98326160
3Locked38.98326100
4Locked40.3662873600
5Locked40.94620900
6Locked38.98326100
7Locked40.36628700
8Locked40.36628700
9Locked38.98326100
10Locked38.98326100
11Locked40.36628700
12Locked38.98326100
13Locked38.60537700
14Locked38.98326100
15Locked38.98326100
16Locked38.98326100
17Locked38.98326100
18Locked38.98326100
19Locked38.98326100
20Locked38.60537700
21Locked38.60537700
22Locked38.60537700
23Locked38.60537700
24Locked38.60537700
26Locked38.60537700
27Locked38.60537700
28Locked37.63627600
29Locked37.63627600
30Locked37.63627620
31Locked37.35598860
32Locked37.63627600
adrianday46
  • 11
Message 4 of 32
3.0 Upstream channels
13260000044.85120 KSym/sec64QAM4
253700000455120 KSym/sec64QAM1
34620000044.55120 KSym/sec64QAM2
43940000044.85120 KSym/sec64QAM3
1US_TYPE_STDMA0010
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
  • 32.22K
  • 3.17K
  • 6.12K
Message 5 of 32
Looks as if either upgrade hasnt been applied or your location isn't 1GB enabled yet. When I look online it says I can get 1GB - but if I actually try to get it (as a test) it wont let me buy it. If you did it through CS - who knows what they did !
To check whether the upgrade has actually been applied (it does sometimes not go through for various reasons), look in the Hub settings for the "Configuration data/file" page (or similar) and see what the numbers are in the Downstream and Upstream boxes reporting "Maximum Data Transfer Rate" (or summat similar) these numbers in bps will show if it been applied. If 1GB should begin.... 1xxxxxxxxx...
adrianday46
  • 11
Message 6 of 32
Details from the configuration tab:
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
SFID
279962
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
279961
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
  • 32.22K
  • 3.17K
  • 6.12K
Message 7 of 32
Ok its been applied but you have no Docsis 3.1 channel. I will flag for VM to come here and comment why that is.
Hayley_S
  • 3.9K
  • 129
  • 253
Message 8 of 32
Hello @adrianday46,
Welcome to the community page, thank you for posting.
I am sorry to see you are having issues with your Gig1 speeds.
I can see you are having some downstream issues, I will send you a private message so I can book a tech for you.
Please look out for a plum envelope at the top right of your screen.
Many thanks,
Hayley
adrianday46
  • 11
Message 9 of 32
The engineer came Friday, said he upped the signal level in the street, changed the wall box and cable from wall box to router. After the hub 4 connected up again samknows realspeed showed 775 speed to hub 4. Now it is showing 221 speed to hub 4.
I mentioned to the engineer that the hub 4 is showing no docsis 3.1 channels, but he said that if it is showing 32 channels, then 8 of them are 3.1.
Connection speed is still poor.
Current stats:
122267500000.536.6QAM25612
1138750000437.4QAM2561
21467500003.937.6QAM2562
31547500004.137.4QAM2563
41627500003.737.6QAM2564
51707500003.738.6QAM2565
61787500003.137.6QAM2566
71867500003.237.6QAM2567
81947500002.437.6QAM2568
92027500001.937.4QAM2569
102107500001.337.4QAM25610
112187500001.337.4QAM25611
132347500000.436.6QAM25613
142427500000.937.4QAM25614
152507500000.636.6QAM25615
162587500000.637.4QAM25616
172667500000.136.6QAM25617
182747500000.136.6QAM25618
19282750000-0.536.6QAM25619
20290750000-0.636.4QAM25620
21298750000-1.236.4QAM25621
22306750000-0.636.4QAM25622
23314750000-1.236.4QAM25623
24322750000-0.736.4QAM25624
25330750000-1.336.4QAM25625
26338750000-1.236.6QAM25626
27346750000-2.135.8QAM25627
28354750000-1.636.4QAM25628
29362750000-2.335.8QAM25629
30370750000-2.235.8QAM25630
31378750000-3.235.1QAM25631
32386750000-3.235.6QAM25632
12Locked36.60965300
1Locked37.35598800
2Locked37.63627600
3Locked37.35598800
4Locked37.63627600
5Locked38.60537700
6Locked37.63627600
7Locked37.63627600
8Locked37.63627600
9Locked37.35598800
10Locked37.35598800
11Locked37.35598800
13Locked36.60965300
14Locked37.35598800
15Locked36.60965300
16Locked37.35598800
17Locked36.60965300
18Locked36.60965300
19Locked36.60965300
20Locked36.38689000
21Locked36.38689000
22Locked36.38689000
23Locked36.38689000
24Locked36.38689000
25Locked36.38689000
26Locked36.60965300
27Locked35.77991100
28Locked36.38689000
29Locked35.77991100
30Locked35.77991120
31Locked35.08354920
32Locked35.59507800
  • 32.22K
  • 3.17K
  • 6.12K
Message 10 of 32
"I mentioned to the engineer that the hub 4 is showing no docsis 3.1 channels, but he said that if it is showing 32 channels, then 8 of them are 3.1."
I am reliably informed by a man who knows about DOCSIS3.1.... that this comment is total BS !
You need VM to get back to you with a reliable explanation as to what is going on - I will flag again
