Gig1 speeds inconsistent and less than expected
Woodham
I have upgraded from M500 to Gig1, and run multiple speed tests over the last couple of days - the download speed results are extremely inconsistent - anywhere between 200 and 900Mbps.
Upload seems fairly consistent around 50Mbps.
Can anyone have a look and see if everything seems ok here?
3.0 Downstream channels
25330750000-1.00000038.983261QAM25625
11387500000.90000238.983261QAM2561
21467500000.70000140.366287QAM2562
31547500000.70000140.366287QAM2563
41627500000.70000140.366287QAM2564
51707500000.90000240.366287QAM2565
61787500001.00000040.946209QAM2566
71867500000.90000240.366287QAM2567
81947500000.70000140.366287QAM2568
92027500000.70000140.366287QAM2569
102107500000.59999840.366287QAM25610
112187500001.00000040.366287QAM25611
122267500001.50000040.366287QAM25612
132347500000.90000240.366287QAM25613
142427500000.70000140.366287QAM25614
152507500000.70000138.983261QAM25615
162587500000.70000138.983261QAM25616
172667500000.59999838.983261QAM25617
182747500000.70000138.983261QAM25618
192827500000.20000138.983261QAM25619
20290750000-0.40000238.983261QAM25620
21298750000-1.00000038.983261QAM25621
22306750000-1.09999838.983261QAM25622
23314750000-1.29999938.605377QAM25623
24322750000-1.00000038.983261QAM25624
26338750000-0.79999938.983261QAM25626
27346750000-0.90000238.983261QAM25627
28354750000-0.79999938.983261QAM25628
29362750000-0.59999838.983261QAM25629
30370750000-0.59999838.983261QAM25630
31378750000-0.59999838.983261QAM25631
25Locked38.98326100
1Locked38.98326100
2Locked40.36628700
3Locked40.36628700
4Locked40.36628700
5Locked40.36628700
6Locked40.94620900
7Locked40.36628700
8Locked40.36628700
9Locked40.36628700
10Locked40.36628700
11Locked40.36628700
12Locked40.36628700
13Locked40.36628700
14Locked40.36628700
15Locked38.98326100
16Locked38.98326100
17Locked38.98326100
18Locked38.98326100
19Locked38.98326100
20Locked38.98326100
21Locked38.98326100
22Locked38.98326100
23Locked38.60537700
24Locked38.98326100
26Locked38.98326100
27Locked38.98326100
28Locked38.98326100
29Locked38.98326100
30Locked38.98326100
31Locked38.98326100
3.1 Downstream channels
33944K1840QAM4096424
33Locked41-0.967091860
5 REPLIES 5
All that looks fine.
How are you testing speeds|? On wifi or ethernet connected devices? What devices? At what site - VM uses ... https://speedtest.samknows.com/ - try on 2 different browsers.
Note wifi speeds will always be less than ~600 as the Hub is only wifi 5 - you need your own wifi 6 enabled wireless equipment to see higher
Thanks for taking a look.
I have been using a variety of different speed test sites, but mostly https://www.speedtest.net/ and the built in speed test on my router (I use the hub in modem mode with my own router - a Unifi UDM)
Apart from the ones directly on my router, I'm testing on a desktop pc with a wired gigabit connection.
Thanks for suggesting that site, I just ran it a few times and again am getting wildly inconsistent results.
Latency
20.4 ms
Jitter
4.40 ms
Download
334 Mbps
Upload
53.7 Mbps
Latency
20.1 ms
Jitter
4.10 ms
Download
410 Mbps
Upload
53.2 Mbps
Latency
17.3 ms
Jitter
2.30 ms
Download
386 Mbps
Upload
53.8 Mbps
I have been running some more speed tests today with a laptop plugged directly into the hub with an ethernet cable (hub still in modem mode, but I restarted it for good measure).
While overall today the numbers are better, they are still inconsistent and not wholly impressive for a supposed 'gigabit' connection.
The best I've seen today is:
Latency
20.5 ms
Jitter
1.50 ms
Download
938 Mbps
Upload
52.9 Mbps
But then I'm also often seeing results like this
Latency
22.2 ms
Jitter
3.20 ms
Download
748 Mbps
Upload
52.1 Mbps
I understand that a gigabit speed isn't technically guaranteed, but these are not very impressive results for a Virgin Network that was only installed in this area 2 or 3 years ago. So far it doesn't seem like the upgrade from M500 is worth it.
Ok, I've been doing some more research and found out about the samknows 'realspeed' test that works with Gig1.
It looks like there's something iffy about the speeds the hub is providing to ethernet connected devices to me - I'm going to try ordering a short new Cat8 cable to rule that out.
The below test was again with a single (short) wired Cat5e cable to a laptop.
Which web browser are you using?
I find the below site consistent:
https://proof.ovh.net/
