Peterzippyreid
  • 29
Message 1 of 37
Gig1 slow speed
Hi i got gig1 installed yesterday and only getting 5mbps on my phone and 200mbps through ethernet
i got 219 mbps on both with my 200meg contract before i upgraded
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 37
Re: Gig1 slow speed
Forget Wi-Fi speeds for now.
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Peterzippyreid
  • 29
Message 3 of 37
Re: Gig1 slow speed
No issues in my area
when i check router staus it just goes to a blank white box
cant even watch catch up tv on my v6 box through ethernet
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Message 4 of 37
Re: Gig1 slow speed
On HUB 4 you need to Log in and look in the Menus for the same page, without that you see the blank box you just did.
Tools > Network Status
Peterzippyreid
  • 29
Message 5 of 37
Re: Gig1 slow speed
checked status and have a red triangle at wireless connections
ethernet is jumping from 200meg down to 5 meg
Peterzippyreid
  • 29
Message 6 of 37
Re: Gig1 slow speed
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Message 7 of 37
Re: Gig1 slow speed
You were asked to post your HUB4 Stats here, also do you have a Broadband Quality Monitor set up from same site you did that test on and FYI not the best Speedtest to use as always low.
Use Speedtest.net as VM recommends and what about the built in App: https://samknows.com/realspeed/
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 37
Re: Gig1 slow speed
Have you set up a BQM ?
Can you please
When the page appears Log In and click ‘Check Router Status’.
Peterzippyreid
  • 29
Message 9 of 37
Re: Gig1 slow speed
Peterzippyreid
  • 29
Message 10 of 37
Re: Gig1 slow speed
What am i doing wrong keep getting checking this image when i try to post pics
