chronicbint
  • 55
Message 1 of 9
Gig1 running at 374
Since getting a Hub4 and Gig1 my speed has gone from a consistent 650 ish(M600) to sub 400. The latency on thinkbroadband is all over the place when before it was consistently ok.
I try to run a check and get this
or this
ArcherH
  • 42
  • 18
Message 2 of 9
Re: Gig1 running at 374
I have exactly the same issue after upgrading a week ago from M600! So frustrating all virgin media want to do is send an engineer out.
chronicbint
  • 55
Message 3 of 9
The router/hub is clearly provisioned wrong or my account is setup wrong. Its capped at around M350 speeds.
More phone calls today, probably spent 5 hours on the phone these past few days.
chronicbint
  • 55
Message 4 of 9
OK, a factory reset has resolved the issue. 😀
Now getting 950 directly connected to the router and 700mb when I switch to modem mode to use my router. Happy with that.
ArcherH
  • 42
  • 18
Message 5 of 9
Was that via a pinhole reset?
Zach_R
  • 4.13K
  • 137
  • 286
Message 6 of 9
Hi @chronicbint,
I am very sorry to hear that you faced some issues with your connection speeds recently. However, I'm glad to hear that these have now been resolved following a factory reset of the router.
Please do let us know if there's anything more that we can assist you with.
Zach - Forum Team
Zach_R
  • 4.13K
  • 137
  • 286
Message 7 of 9
Hi @ArcherH,
I am so sorry to hear that you're having some broadband connection speed issues lately. Are these problems ongoing for you today?
If so, what speeds are you currently getting whilst using a wired connection? You can run a speed test here.
Zach - Forum Team
chronicbint
  • 55
Message 8 of 9
Issues were resolved with a full factory reset thanks. The lady had me hold the pin reset button for a whole minute(not sure that is necessary or not).
Now just have the standard bad latency of the puma chipset 😂 (I would literally pay for a hub 5....)
  • 6.08K
  • 511
  • 1.57K
Message 9 of 9
@chronicbint wrote:
Issues were resolved with a full factory reset thanks. The lady had me hold the pin reset button for a whole minute(not sure that is necessary or not).  <snip>
Yes 60 seconds is recommended. Also do not reboot the Hub after the reset, just let it initialise itself. Takes around 5 minutes or so.
