nublarfan
Message 1 of 5
Gig1 - real speed to router low
Hey guys!
I just got Gig1 today and have been getting ~okay speeds of around 700mbps on WiFi.
I took a look at the Sam Knows RealSpeed test and I'm only getting speeds of around 850mbps to the Hub 4 and 700 to my computer (via WiFi). I get around 900 to my computer via ethernet (higher than the stated speeds to the hub ¯\_(ツ)_/¯)
I've seen a lot of other posts both on here and elsewhere and most people seem to be getting the full 1100mbps to their hub.
Could it be an issue with the connection/cables?
Thanks!
Anonymous
Not applicable
Message 2 of 5
Re: Gig1 - real speed to router low
900Mbps sounds about right, including overheads, on a gigabit ethernet adapter.
Transferring data on my local network only gives 880Mbps:
  • 15.91K
  • 687
  • 1.56K
Message 3 of 5
 Other people use bandwidth on your connection too your can't always get the full speed.
nublarfan
Message 4 of 5
I was referring to the low speed directly to the hub, which is not reaching the advertised speeds.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 5
What is your speed like using SamKnows >> Speed Test <<
