BethAE
  • 9
Message 1 of 13
Gig1 not at Gigabit Speeds and ethernet is much slower than the WiFi
Good afternoon all,
Issue
I have just moved to Virgin Media with a brand new install in my area and I have opted for the Gig1 broadband speeds. Since the install (Yesterday), I have only once managed to achieve a speed at 500mb. The average is between 200-400 on WiFi and 100-200 on Ethernet.
Equipment I am using
I have tried this on numerous devices. I have tried Ethernet on a Lenovo Thinkpad X280 with a Thunderbolt 3 Gen 2 dock, both with 10/100/1000 ethernet. I have also tried ethernet on a 2020 Intel i5 MacBook Air with a 10/100/1000 usb c to ethernet connector. I have also tried wifi on the above, and an iPhone 12, and an iPad Pro 2.
What I have tried
For ethernet, I have tried numerous cables connected directly into the hub 4. I have tried cat5e, cat6 and cat7 cables, all give the same 100-200mb speeds. I have also tried 3 different ethernet usb c adapters.
I have tried the router in both router and modem mode, but no difference in speed. I have done a full pin hole reset, and also rebooted the router a number of times.
I have tried to use SamKnows Real Speed but this is not working? Screenshot 2021-07-15 at 15.22.11.png
I will post all the log details below also. I have also set up a BQM -
https://www.thinkbroadband.com/broadband/monitoring/quality/share/8cebecaa39bac10d5c063d03a974704c4a...
There is a chance I am being too hasty, and it will get better over time, but I am no where near the Gig1 speeds!
BethAE
  • 9
Message 2 of 13
Re: Gig1 not at Gigabit Speeds and ethernet is much slower than the WiFi
Cable Modem Status
Item
Status
Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
BethAE
  • 9
Message 3 of 13
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
25
330750000
6.8
37.6
QAM256
25
1
138750000
8.2
37.4
QAM256
1
2
146750000
8.2
37.6
QAM256
2
3
154750000
7.9
37.6
QAM256
3
4
162750000
7.9
37.6
QAM256
4
5
170750000
8.2
37.6
QAM256
5
6
178750000
8.3
37.6
QAM256
6
7
186750000
8.3
37.4
QAM256
7
8
194750000
8.4
37.6
QAM256
8
9
202750000
8.4
37.4
QAM256
9
10
210750000
8.3
37.6
QAM256
10
11
218750000
8.3
37.6
QAM256
11
12
226750000
8.2
37.4
QAM256
12
13
234750000
8.1
37.6
QAM256
13
14
242750000
7.9
37.6
QAM256
14
15
250750000
7.6
37.4
QAM256
15
16
258750000
7.3
37.6
QAM256
16
17
266750000
7.2
37.4
QAM256
17
18
274750000
7.2
37.6
QAM256
18
19
282750000
7.3
37.6
QAM256
19
20
290750000
7.1
37.6
QAM256
20
21
298750000
6.8
37.4
QAM256
21
22
306750000
6.5
37.4
QAM256
22
23
314750000
6.5
37.6
QAM256
23
24
322750000
6.6
37.4
QAM256
24
26
338750000
7.1
37.4
QAM256
26
27
346750000
7.1
37.6
QAM256
27
28
354750000
7
37.4
QAM256
28
29
362750000
6.8
37.6
QAM256
29
30
370750000
7.1
37.6
QAM256
30
31
378750000
7.3
37.6
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
25
Locked
37.636276
0
0
1
Locked
37.355988
0
0
2
Locked
37.636276
0
0
3
Locked
37.636276
0
0
4
Locked
37.636276
0
0
5
Locked
37.636276
0
0
6
Locked
37.636276
0
0
7
Locked
37.355988
0
0
8
Locked
37.636276
0
0
9
Locked
37.355988
0
0
10
Locked
37.636276
0
0
11
Locked
37.636276
0
0
12
Locked
37.355988
0
0
13
Locked
37.636276
0
0
14
Locked
37.636276
0
0
15
Locked
37.355988
0
0
16
Locked
37.636276
0
0
17
Locked
37.355988
0
0
18
Locked
37.636276
0
0
19
Locked
37.636276
0
0
20
Locked
37.636276
0
0
21
Locked
37.355988
0
0
22
Locked
37.355988
0
0
23
Locked
37.636276
0
0
24
Locked
37.355988
0
0
26
Locked
37.355988
0
0
27
Locked
37.636276
0
0
28
Locked
37.355988
0
0
29
Locked
37.636276
0
0
30
Locked
37.636276
0
0
31
Locked
37.636276
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
159
96
4K
1880
QAM4096
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
159
Locked
41
7.9
1200423
0
BethAE
  • 9
Message 4 of 13
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
26
5120 KSym/sec
64QAM
12
2
46200000
26
5120 KSym/sec
64QAM
11
3
53700000
26
5120 KSym/sec
64QAM
10
4
60300000
26
5120 KSym/sec
64QAM
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
0
0
2
US_TYPE_STDMA
0
0
0
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
0
0
BethAE
  • 9
Message 5 of 13
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
69834ncxv9873254k;fg87dsf
SFID
82
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
81
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
BethAE
  • 9
Message 6 of 13
Quick update:
I have turned the SH4 into modem mode, and connected a TP-Link Archer AX20 Wifi 6 router in.
This has given me some ethernet speeds that are slightly faster (300mbps) and wifi speeds closest to the router of 600mbps.
Is there any reason the ethernet it still much slower than the wifi?
  • 16.28K
  • 711
  • 1.6K
Message 7 of 13
Its always odd when ethernet is slower then wifi but is it from the same device? likely its the device and may need reinstalling don't use a AV they may slow you down.
With your own router try disabling the QoS
SamKnows Real Speed only works in router mode so its odd that that too is not working maybe because your speeds are bad that its not letting you do the test?
BethAE
  • 9
Message 8 of 13
Hi Legacy1,
It certainly is strange.
I have tried turning off my antivirus. One laptop has a VPN for work but even disabling that has no effect. I have tried both WiFi and Ethernet comparatively on all devices possible with the same result, WiFi is always faster.
With my router, QoS is disabled, only ever me at home during the day so I don’t particularly see the benefit of it 🙂
and I did try Sam knows in router mode on all my devices but it still didn’t find it, which does make me wonder if there is potentially a small fault in the hub4?
I mean it all works for now with no huge issue, but would love for speeds closer to what I pay for and a better ethernet connection 🙂
many thanks for your responses!
Kath_F
  • 28.12K
  • 1.08K
  • 2.17K
Message 9 of 13
Hi BethAE,
Thanks for your post and welcome to the forums. It's really great having you on board with us in the Community.
I'm really sorry to hear that you are having issues getting a connection with the higher speeds.
Taking a look a the Hub stats, it is bringing up a pro-longed signal issue. I can see that some of your power levels are borderline too so I would like to arrange for an engineer to come out to get these resolved. Once those are sorted, if you are still having an issue, we can look further into things then.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a private message regarding this. Just click on the little plum envelope at the top right hand side of the page to access your inbox.
Kath_F
BethAE
  • 9
Message 10 of 13
Thanks Kath,
I have just replied 🙂
