philshems
  • 19
Message 1 of 13
Gig1 has recently become much slower and unreliable
Since upgrading to Gig1 and a Hub 4 several months ago, download and upload speeds have been excellent and stable. About a week ago there were a couple of days of intermittent network problems in BR4 and since then speeds have been extremely variable.
Today, using Samknows I measured the following download/upload speeds in the space of an hour:
221 / 1.87
229 / 0.91
1080 / 5.72
Upload speeds seem particularly affected. I'll post BQM graph and router status info next, and if anyone can suggest anything I'd be really grateful.
I've rebooted the router serveral times, and checked all the conncections.
philshems
  • 19
Message 2 of 13
Re: Gig1 has recently become much slower and unreliable
02ff6eb6aeb1eda2b713c6c07e6b44e2a2bb6631-17-07-2021
BQM from today. 2.30pm was my son streaming via Twitch. Lots of dropped frames (20%), when normally there are 0%.
philshems
  • 19
Message 3 of 13
3.0 Downstream channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
11387500002.90000235.972961QAM2561
21467500002.40000236.386890QAM2562
31547500002.29999936.609653QAM2563
41627500002.40000237.636276QAM2564
51707500002.79999938.983261QAM2565
61787500002.70000138.605377QAM2566
71867500002.90000238.605377QAM2567
81947500002.90000238.983261QAM2568
92027500002.79999939.397190QAM2569
102107500002.70000139.397190QAM25610
112187500002.20000139.397190QAM25611
122267500002.59999839.397190QAM25612
132347500002.50000038.983261QAM25613
142427500002.29999938.983261QAM25614
152507500001.79999938.605377QAM25615
162587500001.59999839.397190QAM25616
172667500002.00000038.983261QAM25617
182747500001.70000139.397190QAM25618
192827500001.79999939.397190QAM25619
202907500001.70000138.983261QAM25620
212987500002.40000238.983261QAM25621
223067500002.90000238.983261QAM25622
233147500002.50000038.983261QAM25623
243227500002.40000238.605377QAM25624
253307500001.09999838.983261QAM25625
263387500001.29999938.983261QAM25626
273467500002.40000238.983261QAM25627
283547500002.20000138.983261QAM25628
293627500002.40000238.983261QAM25629
303707500001.00000038.605377QAM25630
313787500000.59999838.983261QAM25631
3.0 Downstream channelsChannel Lock Status RxMER (dB) Pre RS Errors Post RS Errors
1NotLocked35.972961227853212161
2Locked36.3868903141982698
3Locked36.60965331976557328
4Locked37.636276822696139021
5Locked38.9832612512833183
6Locked38.6053772540632730
7Locked38.6053772574529994
8Locked38.9832612558928101
9Locked39.3971902559828725
10Locked39.3971902481529043
11Locked39.3971902509926420
12Locked39.3971902493528031
13Locked38.9832612383729588
14Locked38.9832612493527561
15Locked38.6053772596326394
16Locked39.3971902485629250
17Locked38.9832612531928043
18Locked39.3971902777721609
19Locked39.3971902715622115
20Locked38.9832612757022209
21Locked38.9832613048416794
22Locked38.983261341438230
23Locked38.9832613366510539
24Locked38.605377343627009
25Locked38.983261333231921
26Locked38.983261338192425
27Locked38.983261342036380
28Locked38.983261340152636
29Locked38.983261336402616
30Locked38.6053773254510227
31Locked38.9832613182212255
philshems
  • 19
Message 4 of 13
3.1 Downstream channels
159864K1680QAM2048424
159Locked424.0590376674
philshems
  • 19
Message 5 of 13
3.0 Upstream channels
13260000053.0205995120 KSym/sec64QAM4
23940000053.0205995120 KSym/sec64QAM3
34620000053.0205995120 KSym/sec64QAM2
45370000052.7705995120 KSym/sec64QAM1
1US_TYPE_STDMA0050
2US_TYPE_STDMA0060
3US_TYPE_STDMA0030
4US_TYPE_STDMA0010
philshems
  • 19
Message 6 of 13
Last one from me:
The Network Log is completely blank, so there's nothing to post from there.
  • 24.1K
  • 2.55K
  • 4.37K
Message 7 of 13
Awful BQM!
Someone more used to Hub4 stats needs to comment - but the up speeds all look high and there are a worrying number of PostRS errors - I would reset the Hub to clear them to 0 and see if they then reappear - they shouldnt.  Many are reporting their Logs are not building up - others have put it down to a firmware update glitch
Whilst waiting , have you checked first for “known network faults”
As well as trying the “check service,” Area status webpage" (link at top right of this forum), also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to postcode level.
conman33158
  • 1.55K
  • 131
  • 295
Super solver
Message 8 of 13
Your 3.1 modulation is wrong, should be on QAM4096 plus your upload power levels are maxed out. You definitely have problems and would need an engineers visit.
David_Bn
  • 5.43K
  • 247
  • 449
Message 9 of 13
Thanks for your post @philshems, and I'm sorry to hear of the issues with the services.
Having ran a flow on our system, we would like you to monitor your connection over the next 7 days and come back to us if the issue still persists.
As our flow has identified a very short term connectivity issue which may cause intermittent or performance related issues with your connection.
We believe that the issue is only impacting you connection but it'll only be a very short term issue and the connection will return to normal very soon.
As this is only impacting your connection, can you please check that all cables are connected securely. The issue that has been identified may be the result of a loose connecting cable.
Please check the white coax cable to the hub, as well as the splitters and wall sockets to make sure all cables are connected to the VM equipment securely
Kindest regards,
David_Bn
philshems
  • 19
Message 10 of 13
Thanks David. I'm away for a couple of days but will double check all the connections and then monitor the speed when I get back. Cheers.
