benw1987
Message 1 of 9
Gig1 fibre, not getting what I paid for!!
Hi all,
ive been doing some research on my shocking speeds since moving from M600 to gig1
on m600 I got a steady 550mbps at any given time using Ethernet directly into my hub 3
i plugged my hub4 in and even directly connected via Ethernet with nothing else connected I’m seeing no more than 400mbps
i have checked the docsis channels and I have 31 3.0 channels and 1 3.1 channel, I’ve factory reset the hub 4 and tried a new Ethernet cable and still no luck, please help!!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 9
Re: Gig1 fibre, not getting what I paid for!!
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
benw1987
Message 3 of 9
411mbps to my pc according to that page
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 9
What speed are you getting to the Hub ?
benw1987
Message 5 of 9
1054, seems even more strange now since i've used a few brand new cables (am a network engineer so always have spares)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 9
OK, your WAN Supply seems to be good; just need to work out why you get such low speeds from the Hub to the PC.
Are ALL devices disconnected from the Hub ?
benw1987
Message 7 of 9
yeah, I did a full factory reset on the hub and all my devices connect to a different SSID
The only ethernet in the hub4 is my laptop which has a gigabit NIC with the latest drivers
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 9
Can you boot the PC into 'Safe Mode with Networking' and speed test again please.
Cheule
  • 140
  • 6
  • 13
Up to speed
Message 9 of 9
I found that my PC was unable to keep up with the flow of incoming data, due to my antivirus insisting on checking all packets and getting bogged down.
Virgin 1gbit - Superhub 4 modem mode --> RT-AC3200
