fonggigi
Settling in
Gig1 connect to FTP
Hi, I just joined the Gig1 plan and using Hub4. When I connect company's FTP via Filezilla, the upload speed is only 700KiB/s. I expect at least 10Mb/s. Can anyone point me to the right solution for a faster connection? TIA
muffintastic
  • 155
  • 5
  • 11
Up to speed
Re: Gig1 connect to FTP
How are you connecting WiFi or ethernet?
I suggest if you're using WiFi I would try a wired connection or at least split the WiFi SSID in the router config, so 2.4ghz and 5ghz AC are using different names but same passphrase and not set to "Manage" or something along those lines.
muffintastic
  • 155
  • 5
  • 11
Up to speed
There is a YouTube tutorial on how to do this different router but same firmware when you login.
https://www.youtube.com/watch?v=5R0jzk-vA40
Please not this is NOT MY VIDEO.
  • 6.79K
  • 591
  • 1.78K
Have you discussed this with your Companies IT Department?  It may be a setting on Filezilla that needs changed?
  • 20.46K
  • 828
  • 2.2K
See what speed you get in modem mode with a PC
Steven_L
  • 11.31K
  • 683
  • 1.15K
Hey @fonggigi,
Welcome to the community and thanks for taking the time to post your issue on the forums.
I'm really sorry to hear of the issues that you're having at the moment, I have looked into this and cannot see anything that would be causing these issues, I checked your connection and the local area to be sure and cannot find any problems.
Have you been able to check via a wired connection as some of the members suggested?
Regards,
Steven_L
