bradley
  • 41
Message 1 of 18
Gig1 - but speed less than 100mbs
Hello.
Last couple of days when doing Speedtest - it is less than 100mbs, rather than anywhere near 1Gig!
I did reboot Hub yesterday evening and the speed increased to 900+, as per the guidance on website.
Not really wanting to reboot every time speed drops - can anyone advise or help. (If I only get less than 100mbs I'm not too inclined on paying for Gig1)
Appreciate any guidance.
C_Butcher86
  • 564
  • 190
  • 165
Message 2 of 18
Re: Gig1 - but speed less than 100mbs
Have you used the Samknows QR code to check the speed at the hub before your home network? send me a PM with some more info If you have already tried this.
Thanks Chris
To PM just hover over my profile picture and click Send Message when the option comes up. Please don't post any of the info I've asked for in this thread as it's public
BenMcr
  • 21.44K
  • 2.34K
  • 4.3K
Message 3 of 18
www.samknows.com/realspeed is the direct URL that you can use from any device connected to the Hub 4.
That will test both the connection between Sam Knows and your Hub, and Sam Knows and your device. Speedtest only does a test to your device so can be affected by Ethernet or WiFi problems.
bradley
  • 41
Message 4 of 18
Thank you
Just trying the SamKnows, however getting the following response.
Your SamKnows enabled device is offline
Please check your SamKnows enabled device is turned on and connected to the internet.
Try again
iMac is connected to Hub via ethernet cable. I have switch Hub off and the on and speed back to 940 on Speedtest. How do I get the SamKnows test to run?
bradley
  • 41
Message 5 of 18
Hello,
SamKnows link doesn't work - says the enabled device is offline.
i have switched Hub on and off - speeds goes back up for a while and then reverts to about 95mbs.
Appreciate any further guidance.
Thank you
ian_harker
  • 72
  • 8
Message 6 of 18
I have my H4 in modem mode and samknows don't like that ???
and I have low sped as well
this is going to be a pain to test as I need the internet up as we are on lockdown and have a lot home working and need connectivity for online video meetings and access to NAS storage units which we had to pull from our place of work as the offices are shut and no longer maintained , so cant really keep rebooting the H4 or do tests aaarrrgghhhh
ToffeeSurprise
  • 254
  • 12
  • 82
Fibre optic
Message 7 of 18
You'll have to put the SH4 into normal mode to do a Sam Knows test, you can pop it straight back into modem mode once you're done.
bradley
  • 41
Message 8 of 18
Hello
SamKnows is working and it's showing speed 1040 - so appears to be fine. (I'll cease using the 'Speedtest')
Thank you  for your help.
sjmartinlx
  • 7
Message 9 of 18
Since getting the gig 1 fibre my WiFi speed barely reaches 200,most of the time it's a lot lower, using samknows realspeed the speed to the hub 4 is 1050 -1070 but the WiFi is less than 100. Using the ethernet it's 800ish.
Please help, virgin has changed the cable to the house, no change. The tablet I use is capable of up to 866mbps so surely I should be getting somewhere near that.
SteveM
Tags (3)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 18
You are getting the correct speed to the Hub so the slow Wi-Fi is down to your devices or the environment.
