bradley
  • 41
Gig1 - Very Slow speed
Hello,
Last couple of days, our Gig1 speed is showing approx 36mbs to the router, using SamKnows real speed test link.
Everything connected, correctly, non fault status and no a lot of genuine interest, having contacted 150
Would welcome some support here, especially as only getting a fraction of speed that it is supposed to be.
conman33158
  • 674
  • 63
  • 86
Superfast
Re: Gig1 - Very Slow speed
Can you please upload your router stats
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
For Hubs 2 & 3 - DO NOT LOG IN, just click “Check Router Status”
For Hub 4 - When the page appears LOG IN then click on:
Advanced Settings > Tools > Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again. You can use more than one post for each item if needed.
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Post a 'Live Link' to your BQM on here asap.
Under your graph you just created Click (Share Live Graph) then click generate.
Copy the text in the Direct Link box and paste it on here
bradley
  • 41
Hello,
Details copied below:
3.0 Downstream channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
8195000000-837.6QAM2568
1139000000-1.738.6QAM2561
2147000000-2.538.6QAM2562
3155000000-4.238.6QAM2563
4163000000-4.638.6QAM2564
5171000000-4.938.6QAM2565
6179000000-5.239QAM2566
7187000000-6.137.6QAM2567
9203000000-7.937.4QAM2569
10211000000-7.837.4QAM25610
11219000000-8.535.1QAM25611
12227000000-10.334.9QAM25612
13235000000-10.235.8QAM25613
14243000000-9.735.6QAM25614
15251000000-8.936.4QAM25615
16259000000-9.635.6QAM25616
17267000000-11.135.1QAM25617
18275000000-10.935.6QAM25618
19283000000-11.535.1QAM25619
20291000000-13.334.5QAM25620
21299000000-13.933.7QAM25621
22307000000-12.434.3QAM25622
23315000000-12.234.3QAM25623
24323000000-13.433.4QAM25624
25331000000-14.533QAM25625
26339000000-1532.7QAM25626
27347000000-14.133.5QAM25627
28355000000-15.632.3QAM25628
29363000000-1731.4QAM25629
30371000000-1731.3QAM25630
31379000000-15.132.7QAM25631
3.0 Downstream channelsChannel Lock Status RxMER (dB) Pre RS Errors Post RS Errors
8Locked37.63627600
1Locked38.60537700
2Locked38.60537700
3Locked38.60537700
4Locked38.60537700
5Locked38.60537700
6Locked38.98326100
7Locked37.63627600
9Locked37.35598800
10Locked37.35598800
11Locked35.08354910
12Locked34.92561090
13Locked35.77991100
14Locked35.59507800
15Locked36.38689000
16Locked35.59507810
17Locked35.08354960
18Locked35.59507830
19Locked35.08354900
20Locked34.483570270
21Locked33.7151722130
22Locked34.345688400
23Locked34.345688290
24Locked33.3765914980
25Locked32.96266219330
26Locked32.67620825570
27Locked33.4865423150
28Locked32.32148766610
29Locked31.403784372220
30Locked31.335388484980
31Locked32.67620821510
bradley
  • 41
Further details:
3.0 Upstream channels
14620000047.55120 KSym/sec64QAM3
26030000050.35120 KSym/sec64QAM5
35370000048.85120 KSym/sec64QAM4
43940000046.35120 KSym/sec64QAM2
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
69834ncxv9873254k;fg87dsf
SFID
26021
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
26020
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
conman33158
  • 674
  • 63
  • 86
Superfast
Your downstream power levels are way too low and your upload power levels are too high. Also your SNR on some of the downsteams are too low. Frankly your stats are all over the place 😞
You will need an engineer visit to put this right. Best to ring VM on or just after 8am or alternatively you can wait here for a Virgin staff member to pick it up, but this will typically be between 5-10 days, sometimes sooner, sometimes later depending on how busy they are.
Also Check service status  and also call 0800 561 0061 for most up to date faults information in your area
bradley
  • 41
