  • 13
Message 1 of 7
Gig1 Speed
Hi there,
Recently upgraded from the 350 MB package with a Hub 3 to Gig 1 with a Hub 4 which is in modem mode.
Never had an issue with speed before, always got close or bang on the download and upload speeds advertised.
Although it is still speedy enough for everything that gets thrown at it, the speeds from a variety of speed tests just don’t seem to get close to what they should be at and very noticeable now with upload speeds.
On 350 MB upload would always be at 35 MB - most recent test on Speedtest.net for upload was 20.4 MB so that’s even lower than when I was on the 350 MB package.
It just seems to be like a downgrade rather than an upgrade - Not sure if it’s the connection/levels etc or even just not getting the same performance from the new Hub 4.
Will post the signal levels and logs very shortly.
Appreciate any help that can be given, all equipment is gigabit compatible and tests were done via Ethernet rather than over WiFi.
Using the Hub 4 in either Router / Modem only mode makes little difference with the speeds.
Cheers!
David
  • 13
Message 2 of 7
Re: Gig1 Speed
139000000
Locked
Ranged Upstream Channel (Hz)
39400000
ACTIVE
Provisioning State
Offline
  • 13
Message 3 of 7
Re: Gig1 Speed
1139000000-1.79999935.595078QAM2561
0   UNSUPPORTED0
2147000000-0.09999835.779911QAM2562
3155000000-0.79999935.595078QAM2563
4163000000-2.90000235.083549QAM2564
5171000000-0.29999935.779911QAM2565
61790000001.90000235.779911QAM2566
71870000001.29999935.595078QAM2567
81950000000.90000235.779911QAM2568
9203000000-0.50000035.779911QAM2569
10211000000-1.29999935.779911QAM25610
11219000000-2.90000231.688669QAM25611
12227000000-2.70000133.834164QAM25612
13235000000-1.20000135.595078QAM25613
14243000000-2.00000035.595078QAM25614
15251000000-3.20000134.925610QAM25615
16259000000-4.59999835.083549QAM25616
17267000000-3.09999835.083549QAM25617
18275000000-0.40000235.595078QAM25618
19283000000-1.50000035.595078QAM25619
20291000000-3.59999835.595078QAM25620
21299000000-0.90000235.595078QAM25621
223070000001.40000236.386890QAM25622
233150000000.29999936.386890QAM25623
243230000001.00000036.386890QAM25624
25347000000-1.09999835.779911QAM25625
26355000000-2.50000035.595078QAM25626
27363000000-0.40000236.386890QAM25627
28371000000-1.70000135.779911QAM25628
29379000000-2.90000235.779911QAM25629
30387000000-1.50000035.779911QAM25630
31395000000-0.59999836.386890QAM25631
1Locked000
0NotLocked000
2Locked9693908720
3Locked8728234430
4Locked9070378520
5Locked9633942920
6Locked9644255000
7Locked8973368500
8Locked9640958800
9Locked10178195300
10Locked10245972200
11Locked95869066745520
12Locked930617846370
13Locked10010936800
14Locked6157408540
15Locked5486852480
16Locked23628892180
17Locked5416595610
18Locked5336123420
19Locked5063225120
20Locked4848168000
21Locked5314916010
22Locked5408601300
23Locked36221860900
24Locked9031152600
25Locked9460529200
26Locked9869062200
27Locked9507217800
28Locked9279917900
29Locked9772668900
30Locked10968632000
31Locked71867203000
  • 13
Message 4 of 7
Re: Gig1 Speed
13940000050.5205995120 KSym/sec8QAM4
24620000050.7705995120 KSym/sec8QAM3
35370000052.0205995120 KSym/sec32QAM2
46030000052.5205995120 KSym/sec8QAM1
1US_TYPE_STDMA0020
2US_TYPE_STDMA0020
3US_TYPE_STDMA0020
4US_TYPE_STDMA0020
  • 13
Message 5 of 7
Re: Gig1 Speed
Network LogTime Priority Description
Wed Mar 25 21:25:18 20206CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 4.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Mar 25 22:04:17 20203No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 02:52:22 20206CM-STATUS message sent. Event Type Code: 5; Chan ID: 30; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:30:26 20205MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:30:30 20205RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:30:32 20205RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:30:32 20205RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:30:33 20203No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:31:26 20205Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:31:26 20205TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:31:56 20203Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:46:21 20206CM-STATUS message sent. Event Type Code: 5; Chan ID: 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:52:47 20205MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:52:52 20205RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:52:53 20205RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:52:53 20205RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 08:52:54 20203No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 09:06:12 20205MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 09:06:17 20205RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 26 10:45:38 20206CM-STATUS message sent. Event Type Code: 5; Chan ID: 8; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat Mar 28 12:40:17 20205RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat Mar 28 12:40:36 20206CM-STATUS message sent. Event Type Code: 5; Chan ID: 8; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar 29 08:16:20 20205Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar 29 08:16:35 20206CM-STATUS message sent. Event Type Code: 5; Chan ID: 8; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar 29 22:51:01 20204DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar 29 23:02:15 20206CM-STATUS message sent. Event Type Code: 5; Chan ID: 8; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 30 10:32:37 20204DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 30 13:53:41 20206CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 4.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 30 16:23:25 20204DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 30 19:52:27 20206CM-STATUS message sent. Event Type Code: 5; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 30 20:46:31 20204DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 30 20:53:07 20206CM-STATUS message sent. Event Type Code: 5; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 30 21:30:22 20204DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 30 21:47:10 20206CM-STATUS message sent. Event Type Code: 5; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 30 21:52:17 20204DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 30 21:55:56 20206CM-STATUS message sent. Event Type Code: 5; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • 124
  • 25
  • 25
Message 6 of 7
Re: Gig1 Speed
Please DM me with your account details and I will run a diagnostic check and try to help you.
  • 13
Message 7 of 7
Re: Gig1 Speed
I 'think' I may have cracked it...
I had an additional splitter connected where the connection comes into the property (and have for years - never touched it until now) - thought I would test it and see what it was like should I remove this.
So far so good to what I can tell, a lot snappier.
I will drop over my details via DM if that's OK if you could just check and ensure that I have not made anything worse rather than better that would be much appreciated - Thank you.
Cheers,
David
