enayzed
Gig1 Self-Install: High Ping and Jitter, Power Levels & Connection Quality
I recently self-installed Gig1 in my new home and noticed that compared to my VDSL connection, the ping is double and jitter is higher, particularly on downstream. Upstream performance is better than VDSL. I'm wondering if this could be due to contention, and if so, would both upstream and downstream be affected?
I've also looked into power levels but am unsure how to interpret them. There are a few marginal levels and the variance isn't too significant. Here are the power levels for reference:
1331000000-6.239QAM 25625
2139000000-3.139QAM 2561
3147000000-3.339QAM 2562
4155000000-3.538QAM 2563
5163000000-3.738QAM 2564
6171000000-3.839QAM 2565
7179000000-4.539QAM 2566
8187000000-4.539QAM 2567
9195000000-4.339QAM 2568
10203000000-4.639QAM 2569
11211000000-4.739QAM 25610
12219000000-5.133QAM 25611
13227000000-5.538QAM 25612
14235000000-5.439QAM 25613
15243000000-5.739QAM 25614
16251000000-5.939QAM 25615
17259000000-6.139QAM 25616
18267000000-6.339QAM 25617
19275000000-6.139QAM 25618
20283000000-6.139QAM 25619
21291000000-5.739QAM 25620
22299000000-5.739QAM 25621
23307000000-6.139QAM 25622
24315000000-5.739QAM 25623
25323000000-6.339QAM 25624
26339000000-5.939QAM 25626
27347000000-5.939QAM 25627
28355000000-639QAM 25628
29363000000-6.139QAM 25629
30371000000-6.239QAM 25630
31379000000-639QAM 25631
1Locked3900
2Locked39638124
3Locked391035
4Locked3812613
5Locked3818511
6Locked391551
7Locked397913
8Locked39851
9Locked39600
10Locked392510
11Locked3950
12Locked334942910
13Locked38382
14Locked39321
15Locked39241
16Locked39120
17Locked3990
18Locked39190
19Locked3970
20Locked3940
21Locked3900
22Locked3930
23Locked3900
24Locked3900
25Locked3900
26Locked3900
27Locked3900
28Locked3900
29Locked3900
30Locked3900
31Locked39480
 The previous owner had multiple TV connections, so there are several splitters and open wall points. I plan to disconnect the splitters tomorrow and retest. However, if the issue persists, what can be done to improve ping and jitter on my Gig1 connection?
  • 1.89K
  • 120
  • 438
Super solver
Re: Gig1 Self-Install: High Ping and Jitter, Power Levels & Connection Quality
Gig 1 with mixed mode DOCSIS does have higher latency and jitter than FTTC / VDSL but also more raw bandwidth.
When removing splitters keep a careful eye on the changes to the Downstream and Upstream power levels, each splitter might have at least 4dB of signal loss, so for each removed the DS Power levels and SNR will rise & the US Power level will reduce.
As a guide refer to the section on optimum signal levels ...
https://pickmymodem.com/signal-levels-docsis-3-03-1-cable-modem/
Fastlane256
Hi @enazyzed.
it might be useful to set up a BQM to map the latency, as virgin normally require these if action is required.
You can do that here: https://www.thinkbroadband.com/broadband/monitoring/quality
You may have to change some settings in the hub to make this work to make sure IMCP is not blocked. There are guides on how to do this on thinkbroadband’s website.
If you are still having an issue, I’ll flag it to the staff.
Tags (1)
enayzed
Thank you for your reply, so I remove two splitters and you are right the power levels went up, the SNR stayed the same and the overall performance of the connection latency and jitter stayed the same. I am going to put it down to as you say the underlying technology and maybe a bit of oversubscription in the area.
I am still in my cooling of period so I have called to cancel for now.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
-2.4
39
QAM 256
25
2
139000000
0.7
39
QAM 256
1
3
147000000
0.9
39
QAM 256
2
4
155000000
0.4
39
QAM 256
3
5
163000000
0.2
39
QAM 256
4
6
171000000
0.3
39
QAM 256
5
7
179000000
0.5
39
QAM 256
6
8
187000000
0.4
39
QAM 256
7
9
195000000
0.4
39
QAM 256
8
10
203000000
0.4
39
QAM 256
9
11
211000000
0.7
39
QAM 256
10
12
219000000
0.9
32
QAM 256
11
13
227000000
-1.7
38
QAM 256
12
14
235000000
-1.2
39
QAM 256
13
15
243000000
-1.9
39
QAM 256
14
16
251000000
-1.9
39
QAM 256
15
17
259000000
-2.1
39
QAM 256
16
18
267000000
-2.3
39
QAM 256
17
19
275000000
-1.9
39
QAM 256
18
20
283000000
-2.1
39
QAM 256
19
21
291000000
-1.5
40
QAM 256
20
22
299000000
-1.9
39
QAM 256
21
23
307000000
-1.6
40
QAM 256
22
24
315000000
-2
39
QAM 256
23
25
323000000
-2.1
40
QAM 256
24
26
339000000
-1.8
40
QAM 256
26
27
347000000
-2.3
40
QAM 256
27
28
355000000
-2.2
40
QAM 256
28
29
363000000
-2.2
40
QAM 256
29
30
371000000
-2.3
40
QAM 256
30
31
379000000
-2.1
40
QAM 256
31
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
39
694
1299
2
Locked
39
16015
256
3
Locked
39
39069
1056
4
Locked
39
30068
1406
5
Locked
39
41746
1277
6
Locked
39
30444
543
7
Locked
39
31465
317
8
Locked
39
26671
1037
9
Locked
39
28922
961
10
Locked
39
2837
936
11
Locked
39
1708
919
12
Locked
32
36311
1726
13
Locked
38
131
2610
14
Locked
39
723
1636
15
Locked
39
677
1290
16
Locked
39
575
1030
17
Locked
39
381
541
18
Locked
39
347
504
19
Locked
39
476
562
20
Locked
39
492
609
21
Locked
40
684
1098
22
Locked
39
679
1229
23
Locked
40
719
1670
24
Locked
39
749
1556
25
Locked
40
618
1175
26
Locked
40
169
280
27
Locked
40
238
259
28
Locked
40
45
145
29
Locked
40
585
1197
30
Locked
40
564
904
31
Locked
40
1495
1441
Paul_DN
  • 10.7K
  • 546
  • 1.09K
Hi enayzed,
Thank you for reaching out to us in our community and welcome back, it has been a while, sorry to hear you are facing high ping and jitter, I was unable to locate you on our system with the details we have for you, so I can help and have a look at things our end I will send you an invite into a private chat, once received please click on the purple envelope to accept.
Paul.
Paul_DN
  • 10.7K
  • 546
  • 1.09K
Hi enayzed,
Thank you for joining me in a private chat, sorry to hear you have now cancelled due to the issues you are facing, we wish you all the luck and hope you may consider returning in the future, apologies again for any inconvenience caused.
Paul.
