apj_uk
  • 31
Gig1 - Hub 4 - alternative WiFi router suggestions...
As a new Gig1 customer, I am completely unimpressed by just about every aspect of the Hub 4, especially the poor WiFi speeds - even when I am within a few feet of the router using different mobile devices, I am getting about 500mb at best after lots of faffing about with WiFi channel changes etc.
Can anyone suggest a good tried and tested WiFi router that will help me achieve better Gig1 WiFi speeds around my home please?
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Re: Gig1 - Hub 4 - alternative WiFi router suggestions...
what speed do your wifi devices support?
2.4Ghz maxes out at 300Mbps
5Ghz "n" maxes out at 900Mbps
5Ghz "ac" has a range of 433 Mbps - 1.7 Gbps
of course ,those are maximum theortical speeds.
Range comparison – 2.4 GHz vs. 5 GHz
Standard Frequency Theoretical Distance Real World Distance
802.11a5Ghz390 ft195 ft
802.11b2.4Ghz460 ft230 ft
802.11g2.4Ghz125 ft62 ft
802.11n2.4Ghz820 ft410 ft
802.11n5Ghz460 ft230 ft
802.11ac5Ghzup to 820 ft (amplified)up to 410 ft (amplified)
Speed comparison – 2.4 GHz vs. 5 GHz
Standard Frequency Theoretical Speed Real-World Speed
802.11a5Ghz6-54 Mbps3 - 32 Mbps
802.11b2.4Ghz11 Mbps2-3 Mbps
802.11g2.4Ghz54 Mbps10 -29 Mbps
802.11n2.4Ghz300 Mpbs150 Mbps
802.11n5Ghz900 Mbps450Mbps
802.11ac5Ghz433 Mbps - 1.7 Gbps210 Mbps - 1 G
My Broadband Ping - spgray
Timwilky
  • 320
  • 10
  • 46
Fibre optic
500Mb on a WiFi connection is not bad.
What devices are you trying to connect by WiFi and what is their network specifications? Are they able to use a faster wifi?
The hub 4 is a poorly spec'd device, limited to 1Gb ports, no WiFi 6 (although we are all waiting for 6e) So for a new device not future proof we will be wanting a hub5 when speeds start to exceed 1Gb,
Personally I do not recommend WiFi "routers", they are generally low spec as a gate way device. Fine to run as cheap access points to deliver WiFi connectivity to the home network.
