on 07-07-2022 14:05
Hello awesome community, I hope you are well.
So for some strange reason since my issues started with random dropouts just over 1 month ago my wired desktop PC is not getting anywhere close to Gig1 speeds.
I've got a decent desktop PC with all the latest updates running on Windows 11. I've tried different cables CAT 6, CAT 8 but speeds are around 180 Mbps on Speedtest also tried thinkbroadband with comes with similar results.
What's strange is the fact that when using website https://samknows.com/products/realspeed speed to Virgin Media 4 is flawless around 950+ Mbps , speed to computer drops down to 150 Mbps .
I managed to register with
Hopefully someone can share some light on whats happening.
on 07-07-2022 14:07
I forgot to mention my Upload speeds are fine, no issues with this at all.
on 07-07-2022 14:51
It will be the speed to the hub with VM will fix if there is an issue. Try the following for a speedtest:
Reboot PC
Close every app that may be using any processor
Load Edge or Chrome and then run https://samknows.com/realspeed/
on 07-07-2022 15:06
