Fidder2020
  • 9
Gig 1 slow speed
 Very slow speeds on Sam knows, tried rebooting more than once, still slow.
David_Bn
  • 8.67K
  • 363
  • 670
Re: Gig 1 slow speed
Thanks for your post on our Community Forums @Fidder2020.
Are you able to run a speed test via a Cat 6 Ethernet cable, and with the hub in modem mode? This will tell us what speed we have going into your property. If this reads as the subscribed speed (or slightly above) this may be a case of an issue with the Wi-Fi facility, or the set up of your home to accommodate a Wi-Fi connection.
If this is below the subscribed speed, this may be an issue outside the property that needs to be rectified
Kindest regards,
David_Bn
