Message 1 of 7
Gig 1 download speed has deteriorated recently
I upgraded to Gig 1 about a month ago, and initially all was well and I could download at around 950 meg. Over the past couple of weeks however, I have noticed that the download speed has reduced significantly to around 200-300 meg most of the time, with only short daytime bursts back up to around 800-900 meg.
I am using the hub 4 in modem mode connected to a Unifi USG 3P router and then off to a gigabit switch. I've tested the speed straight from the hub with similar results. I have reset all the devices, left the hub off for 10 minutes unplugged and so on, and none of it has helped.
Below is my broadband speed, checked using speedtest.net every 15 minutes. This is being run on a Raspberry Pi 4, so I'd take anything over 700 as an indicator that I'm getting full speed.
The red bar around 11pm is from unplugging and restarting the router. The latency spikes correlate to the speed tests being done as above.
My Broadband Ping - Virgin Media 1 Gig
There is a 10db wideband attenuator which was installed by the engineer along with the previous hub 3. This has not been removed as-yet.
If anyone can help I'd very much appreciate it.
Router status logs:
3.0 Downstream channels
5 171000000 0.599998 38.983261 QAM256 5
1 139000000 2.099998 38.983261 QAM256 1
2 147000000 1.700001 40.366287 QAM256 2
3 155000000 1.299999 38.983261 QAM256 3
4 163000000 1.000000 38.983261 QAM256 4
6 179000000 0.500000 38.983261 QAM256 6
7 187000000 0.299999 38.983261 QAM256 7
8 195000000 0.099998 38.983261 QAM256 8
9 203000000 0.000000 38.605377 QAM256 9
10 211000000 -0.099998 38.983261 QAM256 10
11 219000000 -0.200001 38.983261 QAM256 11
12 227000000 -0.200001 38.983261 QAM256 12
13 235000000 -0.200001 38.605377 QAM256 13
14 243000000 -0.400002 38.983261 QAM256 14
15 251000000 -0.700001 38.605377 QAM256 15
16 259000000 -0.900002 38.983261 QAM256 16
17 267000000 -0.700001 40.366287 QAM256 17
18 275000000 -0.099998 40.366287 QAM256 18
19 283000000 -0.099998 40.366287 QAM256 19
20 291000000 -0.200001 40.366287 QAM256 20
21 299000000 -0.099998 40.366287 QAM256 21
22 307000000 -0.299999 40.366287 QAM256 22
23 315000000 -0.500000 38.983261 QAM256 23
24 323000000 -0.799999 38.983261 QAM256 24
25 347000000 -0.900002 38.983261 QAM256 25
26 355000000 -0.799999 38.983261 QAM256 26
27 363000000 -1.000000 38.605377 QAM256 27
28 371000000 -1.299999 38.983261 QAM256 28
29 379000000 -1.500000 38.983261 QAM256 29
30 387000000 -1.500000 38.605377 QAM256 30
31 395000000 -1.200001 38.983261 QAM256 31
5 Locked 0 0 0
1 Locked 142556465 0 0
2 Locked 138244513 0 0
3 Locked 127170669 0 0
4 Locked 139833198 0 0
6 Locked 138190393 0 0
7 Locked 125257210 0 0
8 Locked 128300211 0 0
9 Locked 140105404 0 0
10 Locked 140443288 0 0
11 Locked 126092563 0 0
12 Locked 1722904835 0 0
13 Locked 111937237 0 0
14 Locked 112465438 0 0
15 Locked 102827432 0 0
16 Locked 99316448 0 0
17 Locked 109868248 0 0
18 Locked 108050297 0 0
19 Locked 99330019 0 0
20 Locked 102592966 0 0
21 Locked 111697705 0 0
22 Locked 112940391 0 0
23 Locked 102884101 0 0
24 Locked 114716126 0 0
25 Locked 127824693 0 0
26 Locked 127509929 0 0
27 Locked 116349055 0 0
28 Locked 128923091 0 0
29 Locked 140162239 0 0
30 Locked 166106938 0 0
31 Locked 3598501093 0 0
3.1 Downstream channels
159 96 4K 1880 QAM4096 759
159 Locked -6.0 43337595 0
3.0 Upstream channels
1 60300000 50.520599 5120 KSym/sec 64QAM 9
2 39400000 50.520599 5120 KSym/sec 64QAM 12
3 46200000 50.520599 5120 KSym/sec 64QAM 11
4 53700000 50.020599 5120 KSym/sec 64QAM 10
1 US_TYPE_STDMA 0 0 1 0
2 US_TYPE_STDMA 0 0 1 0
3 US_TYPE_STDMA 0 0 1 0
4 US_TYPE_STDMA 0 0 1 0
Thu 24/09/2020 04:28:08 6 CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 08:57:24 4 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 16:49:13 4 DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 16:49:13 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 27/09/2020 17:09:38 4 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 28/09/2020 12:53:27 4 DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 28/09/2020 12:53:27 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 28/09/2020 23:50:52 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:30:25 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:30:25 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:30:26 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:32:23 3 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:35:23 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:35:44 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:38:31 3 DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:39:04 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:40:12 3 DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:40:35 4 Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:41:05 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:42:17 3 DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:42:44 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:44:23 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 01:44:26 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 02:13:55 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 02:13:55 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/10/2020 04:28:12 6 CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/10/2020 09:14:05 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/10/2020 09:14:09 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/10/2020 09:14:31 6 CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 02/10/2020 14:13:55 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 02/10/2020 14:13:55 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 04/10/2020 08:33:39 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 06/10/2020 02:13:56 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 06/10/2020 02:13:56 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 06/10/2020 02:43:56 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 06/10/2020 02:43:56 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 06/10/2020 21:29:37 6 CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: 195330; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 18:27:21 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 19:26:47 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 08/10/2020 04:28:26 6 CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 09/10/2020 22:23:33 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 10/10/2020 10:51:26 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 10/10/2020 10:51:26 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 13/10/2020 13:17:43 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 13/10/2020 13:17:43 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 17/10/2020 01:17:43 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 17/10/2020 01:17:43 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 17/10/2020 22:14:10 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • 11.77K
  • 917
  • 1.51K
Message 2 of 7
Re: Gig 1 download speed has deteriorated recently
Can you post a 'Live Link' to your BQM please.
Mike Robinson
  • 11.77K
  • 917
  • 1.51K
Message 3 of 7
What speed do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Message 4 of 7
Hi Mike,
Please see here: My BQM
Many thanks,
Peter
Message 5 of 7
Hi Mike,
I must admit I wasn't looking forward to messing with all the cables, but after setting it back to router mode and connecting it to a fast enough machine, I could see around 1040Mbps to the hub and 950Mbps or so to the PC, so it looks like the problem is on my side.
Many thanks,
Peter
  • 11.77K
  • 917
  • 1.51K
Message 6 of 7
Do a quick line drawing of your setup and we will see if there are any conflicts that could be causing your problem.
Mike Robinson
  • 3.62K
  • 280
  • 500
Superfast
Message 7 of 7
@PeterSeymour wrote:
Hi Mike,
Many thanks,
Peter
It's worth checking if this value has changed since the 'cable messing':
