NickTSW
Settling in
Getting less than minimum guarenteed on 350MB package
Ever since my 12 month package deal was over and I started paying a little more, my speeds seem to have dropped to around 60mbps.
It's been like this for around 2 weeks now.
jpeg1
  • 4.54K
  • 254
  • 729
Superstar
Re: Getting less than minimum guarenteed on 350MB package
What devices are you measuring this speed on, and how are they connected to the Hub?
NickTSW
Settling in
On my PC using an ethernet cable
jpeg1
  • 4.54K
  • 254
  • 729
Superstar
We need to check the connection then.
Go to the Hub on 192.168.0.1. Click on front page the link Check Router Status.
Copy and paste here the data for Upstream, Downstream, and Network Log.  Use data copy rather than screen shots
NickTSW
Settling in
1 363000000 -2.2 38 256 qam 29
2 203000000 -0.4 38 256 qam 9
3 211000000 -0.4 38 256 qam 10
4 219000000 -0.7 38 256 qam 11
5 227000000 -0.7 38 256 qam 12
6 235000000 -0.7 38 256 qam 13
7 243000000 -1.4 38 256 qam 14
8 251000000 -1.7 38 256 qam 15
9 259000000 -2 38 256 qam 16
10 267000000 -1.7 38 256 qam 17
11 275000000 -1.9 38 256 qam 18
12 283000000 -2 38 256 qam 19
13 291000000 -1.9 38 256 qam 20
14 299000000 -2 38 256 qam 21
15 307000000 -1.9 38 256 qam 22
16 315000000 -1.9 38 256 qam 23
17 323000000 -1.7 38 256 qam 24
18 331000000 -1.7 38 256 qam 25
19 339000000 -1.7 38 256 qam 26
20 347000000 -1.7 38 256 qam 27
21 355000000 -2 38 256 qam 28
22 371000000 -2.4 38 256 qam 30
23 379000000 -2.5 38 256 qam 31
24 387000000 -2.5 38 256 qam 32
08/06/2020 20:55:3 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 11:53:54 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 11:53:54 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 09:03:5 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 07:27:0 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 00:30:47 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 21:42:56 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 20:36:9 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 13:07:43 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 08:00:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/06/2020 15:09:19 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/06/2020 13:39:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/06/2020 11:50:21 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/06/2020 17:31:33 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/06/2020 01:38:33 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/06/2020 01:38:33 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 21:39:47 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2020 16:39:10 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2020 11:42:8 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/05/2020 01:37:32 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
jpeg1
  • 4.54K
  • 254
  • 729
Superstar
The Downstream looks OK. Can you post the upstream as well as that can affect the downstream.
Two other things to try:
Reset the Hub to factory default with the pin hole for 30 secs. This will reset any passwords you had changed.  Replace the ethernet cable with another,
Good luck with that - I'm off to the dentist for a long delayed appointment!
