stuartp2
  • 7
Message 1 of 11
Getting 3Mbps download speed on my 100mb connection
Hi All.
For the past few nights I have been getting extremely erratic speeds on my connection. At the moment it's 3mb. Then the next hour it will be back up to 10mb then full speed then back to 3.
Can anyone help? It's practically unusable at the moment.
Posting my diagnostics below.
13307500006.340256 qam25
22027500006.540256 qam9
32107500006.540256 qam10
42187500006.540256 qam11
52267500006.440256 qam12
62347500006.540256 qam13
72427500006.440256 qam14
82507500006.540256 qam15
92587500006.840256 qam16
102667500006.640256 qam17
112747500006.540256 qam18
122827500006.540256 qam19
132907500006.540256 qam20
142987500006.840256 qam21
153067500006.440256 qam22
163147500006.340256 qam23
173227500006.340256 qam24
183707500006.140256 qam26
193787500006.140256 qam27
203867500006.440256 qam28
213947500006.540256 qam29
224027500006.440256 qam30
234107500006.140256 qam31
244187500006.440256 qam32
1Locked40.93028631
2Locked40.3108581513
3Locked40.397821347
4Locked40.391431215
5Locked40.390451214
6Locked40.380541137
7Locked40.972641001
8Locked40.365551055
9Locked40.36003889
10Locked40.36050834
11Locked40.35631785
12Locked40.94715833
13Locked40.34441705
14Locked40.34076729
15Locked40.33660591
16Locked40.33590733
17Locked40.33213573
18Locked40.31805573
19Locked40.31803479
20Locked40.31561697
21Locked40.31525611
22Locked40.31422633
23Locked40.91210640
24Locked40.31107440
stuartp2
  • 7
Message 2 of 11
Re: Getting 3Mbps download speed on my 100mb connection
Rest of logs
13940000047.5512064 qam4
24620000047.3512064 qam3
35370001947512064 qam2
46030000045.8512064 qam1
2ATDMA0050
3ATDMA0010
4ATDMA0010
29/12/2020 20:55:38noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 16:47:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 20:19:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 04:05:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 04:04:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 03:40:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 20:13:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 19:14:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 19:10:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 15:04:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 12:17:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 12:17:39criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 11:49:10Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 08:00:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 23:23:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 08:05:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 06:35:9criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 05:14:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 05:01:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 05:00:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 11
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Please post a 'Live Link' to your BQM on here.
stuartp2
  • 7
Message 4 of 11
Thanks for your reply.
I don't have cable handy at the moment but here's a link to the monitor I set up earlier
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e96552d1ad2a9f97af42b222d993f8259f...
Connection seemed fine most of the day apart from a complete drop out for a few minutes but now it's back down to about 10mbs.
It really does seem to be something that only happens in the evening.
stuartp2
  • 7
Message 5 of 11
As I typed that it's now down to 3mbs again and Netflix Is unusable.
Anonymous
Not applicable
Message 6 of 11
Looks like overutilization on the BQM.
stuartp2
  • 7
Message 7 of 11
Is that something that I would need to call virgin about or will someone eventually pick up on my issue in here?
Is it even fixable?
Anonymous
Not applicable
Message 8 of 11
Is it even fixable?
Fixable yes, timelines are another question.
Lots of VM users on here complaining about slow speeds at peak times. You can clearly see this on your BQM:
You can phone it in however not sure how far you will get.
You can:
  • Wait for a response from one of the VM staff on here (1 - 2 weeks).
  • Text 07533 051 809.
  • Contact by phone 0345 454 1111 (8am is best).
stuartp2
  • 7
Message 9 of 11
Thanks.
Tried the text thing yesterday, it said they would get back to me within 4 hours and I haven't heard a thing since.
Hopefully someone picks it up from here.
stuartp2
  • 7
Message 10 of 11
Been terrible since about 4pm today.
It's consistently below 10mps.
Just incase anyone at virgin ever reads this.
