philipbroadhead
Message 1 of 8
Getting 250mb max on Virgin Gigabit
Hello all,
Recently upgraded to Gigabit from 350mb package and unfortunately i've not really reached anything close to that since!
I've just run a cable directly from the router (3rd party, but I was having the same issues with the Hub 4) to my PC and I've not seen speeds improve from using powerline as I was previously.
Is there anything I can do to speed it up?  Obviously would like to be hitting 1gig or somewhat close to that if i'm paying for it...
Cheers 🙂
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Getting 250mb max on Virgin Gigabit
What speed do you get at >> Sam Knows Real Speed << using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
DJ_Shadow1966
  • 7.11K
  • 1.36K
  • 2.02K
Message 3 of 8
Hello
If the hub is in modem mode and you run https://samknows.com/realspeed/ what results do you get ?
Using power lines can be very hit and miss depending on the condition of the mains wiring.
What router are you running, are you running the hub 4 in router mode ?
One of the issues I see is the default Gigabit Ethernet has a potential frame throughput of 81000 per second and therefore a high throughput for actual data (about 118 MB/s), giving efficiency of 94%, or 940Mbps.
Regards Mike
philipbroadhead
Message 4 of 8
The hub is in modem mode currently, with a Netgear Nighthawk X6 R8000 between it and myself.
Trying to run the samknows test with it in modem mode just says no router found.  Interestingly, when I had the Hub 4 in router mode and ran that test, I was getting the gigabit speed coming into the building!
I was using powerline adapters until this morning but now am running a cable directly from my Netgear router to my PC.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 8
Sam Knows Real Speed will only work to the VM Hub.
philipbroadhead
Message 6 of 8
That's what I thought but the bloke above said in modem mode so I gave it a try 😉
I've just connected a Windows laptop directly into the Netgear with a short cable and it's maxing out around 250mb.
Strangely, after the upgrade I was managing around 400-420 tops over powerline but that soon slowed down and never reached those heights again.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 8
The idea behind the Hu4  and the Gigabit connection is to have multiple high speed connections from the Hub not just a single gigabit connection.
I have been trying to find an adaptor that will combine 4 ethernet inputs into 1 output but haven't had any joy up to now.
philipbroadhead
Message 8 of 8
Well!
Just put the Hub back in router mode, connected everything up to it and turned the Netgear off and, lo and behold, lovely gigabit speeds!
Fingers crossed they stay like that. 🙂
Thanks for the help guys.
