Geting 2 to 3 mb download on wifi and ethernet on a 100mb contract
Please help
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1315000000-2.540256 qam23
2139000000-3.938256 qam1
3147000000-2.538256 qam2
4155000000-237256 qam3
5163000000-2.738256 qam4
6171000000-2.238256 qam5
7179000000-1.738256 qam6
8187000000-1.440256 qam7
9195000000-1.540256 qam8
10203000000-1.940256 qam9
11211000000-1.938256 qam10
12227000000-1.926256 qam12
13235000000-1.740256 qam13
14243000000-1.740256 qam14
15251000000-1.540256 qam15
16259000000-1.540256 qam16
17267000000-1.740256 qam17
18275000000-240256 qam18
19283000000-1.740256 qam19
20291000000-1.738256 qam20
21299000000-2.240256 qam21
22307000000-2.540256 qam22
23323000000-2.738256 qam24
1Locked40.960
2Locked38.611186
3Locked38.629030
4Locked37.631827
5Locked38.943927
6Locked38.91046
7Locked38.91190
8Locked40.3260
9Locked40.350
10Locked40.9160
11Locked38.6110
12Locked26.9838171819189144
13Locked40.3200
14Locked40.340
15Locked40.360
16Locked40.360
17Locked40.940
18Locked40.900
19Locked40.350
20Locked38.950
21Locked40.350
22Locked40.360
23Locked38.950
Upstream
1537000484.95512064 qam2
2394001564.95512064 qam4
3462001664.95512032 qam3
4602999884.95512064 qam1
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Network LogTime Priority Description
09/06/2020 20:51:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2020 20:51:37Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2020 20:50:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 3.52K
  • 567
  • 1.38K
Re: Geting 2 to 3 mb download on wifi and ethernet on a 100mb contract
Your signal to noise ratio on channel 12 is far too low, so the hub is struggling to communicate with the network.
Usually that's an easy fix, but will require a technician visit.  You can try phoning in (first thing in the morning is best), or you can wait for the forum staff to pick this up and advise.  I'd recommend the latter - VM's offshore call centre is dismal, and the agent will insist you go through all manner of pointless messing around because that's what the script tells them to do, and they mostly have no understanding of the technology they are supposed to be supporting.
Thank you Andruser,
Good advice. I'm waiting for a response from the forum staff on this. I've gone through the resets and tests so many times, it would be great to find someone who knows the technology to help me out here.
  • 1.35K
  • 91
  • 131
Hi GLBJ,
Welcome to the community! I am sorry to see that you have been experiencing various issues with your broadband connection.
As Andruser correctly pointed out, you are currently being impacted by an SNR (signal to noise ratio) issue which will require an engineer's visit to resolve. I have booked you in with an engineer appointment which you can find the allocated time slot of on your online account. This time slot can be rearranged from there too if needed.
If there's anything else I can do for you please just let me know.
Kindest regards,
Beth
Hi Beth_G
Thanks for the response. I checked under my orders and don't see any appointments. Can you please confirm it has been added? Or message me privately with the details?
  • 1.35K
  • 91
  • 131
Hi GLBJ,
Thanks for letting me know - I've double checked and it's definitely booked in on our end.
I will pop you over a PM to confirm 🙂
Apologies for any confusion.
Beth
