dazdean69
  • 19
Message 1 of 29
Gaming lag on gigabit speed
Hi folks,
We have recently switched to the Gigabit connection and regularly get speeds of 950 download, 52 upload with a ping of 7ms.
the issue we are getting is , we have a pc connected via ethernet which is used primarily for competitive gaming, nearly every day there is gaming lag / jitter. I have accessed the Hub 4 settings and opened ports etc but the lag continues. it is getting frustrating to know where to go next and what to do can anyone point me in the right direction?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 29
Re: Gaming lag on gigabit speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
dazdean69
  • 19
Message 3 of 29
Thanks for replying so quickly
I have added the link to thinkbroadband.com but the router status page is a blank white pageMy BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 29
What do you get if you don't log in ?
dazdean69
  • 19
Message 5 of 29
3.0 Downstream channels Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
253310000007.09999840.366287QAM25625
11390000005.50000038.983261QAM2561
21470000005.69999738.983261QAM2562
31550000005.90000238.605377QAM2563
41630000006.00000038.983261QAM2564
51710000006.00000038.983261QAM2565
61790000006.00000038.605377QAM2566
71870000005.80000338.983261QAM2567
81950000005.80000338.983261QAM2568
92030000005.80000338.983261QAM2569
102110000005.59999838.983261QAM25610
112190000005.50000040.366287QAM25611
122270000005.30000338.983261QAM25612
132350000005.19999738.983261QAM25613
142430000005.19999740.366287QAM25614
152510000005.00000038.983261QAM25615
162590000005.40000238.983261QAM25616
172670000006.00000040.366287QAM25617
182750000006.09999840.366287QAM25618
192830000005.90000238.983261QAM25619
202910000005.90000238.983261QAM25620
212990000006.40000238.983261QAM25621
223070000006.90000240.366287QAM25622
233150000007.19999740.366287QAM25623
243230000007.30000340.366287QAM25624
263710000005.90000238.983261QAM25626
273790000005.19999740.946209QAM25627
283870000005.09999838.983261QAM25628
293950000005.19999738.983261QAM25629
304030000005.30000338.983261QAM25630
314110000005.50000040.366287QAM25631
3.0 Downstream channels Channel Lock Status RxMER (dB) Pre RS Errors Post RS Errors
25Locked000
1Locked116723597200
2Locked117286877500
3Locked229799438200
4Locked118184811100
5Locked114775409700
6Locked118309319200
7Locked117982246900
8Locked143793474100
9Locked33057655500
10Locked32807121000
11Locked32782254900
12Locked32663037000
13Locked32415909200
14Locked31288392400
15Locked32578339800
16Locked33073101500
17Locked33811801800
18Locked33963658200
19Locked33544024900
20Locked32583098400
21Locked33601658200
22Locked32567488000
23Locked32113479700
24Locked50696480900
26Locked50646721800
27Locked50709005000
28Locked50345252400
29Locked50299410800
30Locked50488335100
31Locked248736692000
3.1 Downstream channels Channel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33804K1560QAM4096424
3.1 Downstream channels Channel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33Locked 5.21995400830
dazdean69
  • 19
Message 6 of 29
3.0 Upstream channels
12580000054.2705995120 KSym/sec64QAM12
23940000053.7705995120 KSym/sec64QAM9
34620000052.7705995120 KSym/sec64QAM8
43260000053.0205995120 KSym/sec64QAM10
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
dazdean69
  • 19
Message 7 of 29
Network LogTime Priority Description
Thu 01/01/1970 00:01:223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 13/09/2020 19:32:155MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:193No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 14/09/2020 18:40:265MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 16/09/2020 22:54:214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:173No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 18/09/2020 19:57:545MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 19/09/2020 08:39:155RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 19/09/2020 08:39:356CM-STATUS message sent. Event Type Code: 4; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/09/2020 02:18:224DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 23/09/2020 07:46:535MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 25/09/2020 05:01:003No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 25/09/2020 09:50:324DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 28/09/2020 03:41:403No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 28/09/2020 12:34:274DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/10/2020 01:15:533No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 02/10/2020 00:34:274DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 05/10/2020 03:41:543No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 05/10/2020 12:34:274DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 08/10/2020 07:53:195MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 10/10/2020 10:13:514DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 11/10/2020 05:20:213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 13/10/2020 05:54:144DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 15/10/2020 17:23:243No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 16/10/2020 17:54:144DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:203No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 21/10/2020 05:59:255MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 19:59:153No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 22:44:015MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 22:44:115RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 22:44:306CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 25/10/2020 02:19:054DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Anonymous
Not applicable
Message 8 of 29
Your upstream power levels a touch high:
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
The BQM should give a better picture.
dazdean69
  • 19
Message 9 of 29
HI Mike,
Sorry I missed the bit that said log in with a hub 4 and then copy and paste
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 29
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
