ClayforthDoyle
  • 8
Message 1 of 9
Frequent outages and speed drops
Hi all,
For the past few days my broadband speed has been shockingly poor, multiple times throughout the day the speed drops to horrendous low levels, example I am on M200 package, the max speed I get is 132Mbps, the drops are all the way down to 0.8Mbps, which then slowly climbs up to about 30Mbps. Resetting the router sometimes helps, but not often, it's just a case of waiting until it's okay, in the meantime having to use my mobile data for my children to do there school work.
I will follow this post with the information from the router status.
299000000
Locked
Ranged Upstream Channel (Hz)
39399976
Locked
Provisioning State
Online
ClayforthDoyle
  • 8
Message 2 of 9
Re: Frequent outages and speed drops
12990000007.638256 qam21
2139000000737256 qam1
3147000000737256 qam2
41550000007.438256 qam3
51630000007.538256 qam4
6171000000837256 qam5
71790000008.337256 qam6
81870000008.437256 qam7
91950000008.337256 qam8
102030000008.137256 qam9
11211000000837256 qam10
122190000007.837256 qam11
132270000007.637256 qam12
142350000007.537256 qam13
152430000007.638256 qam14
16251000000838256 qam15
17259000000838256 qam16
182670000007.538256 qam17
192750000007.538256 qam18
202830000007.638256 qam19
212910000007.638256 qam20
223070000007.138256 qam22
233150000007.138256 qam23
243230000007.138256 qam24
1Locked38.990
2Locked37.6180
3Locked37.3110
4Locked38.6240
5Locked38.6130
6Locked37.6230
7Locked37.3380
8Locked37.6210
9Locked37.3150
10Locked37.3250
11Locked37.3180
12Locked37.6110
13Locked37.390
14Locked37.690
15Locked38.680
16Locked38.680
17Locked38.6130
18Locked38.690
19Locked38.690
20Locked38.990
21Locked38.980
22Locked38.6110
23Locked38.6150
24Locked38.660
ClayforthDoyle
  • 8
Message 3 of 9
1393999764.9512064 qam10
2258000655.1512064 qam12
3326000044.9512064 qam11
4462000094.9512064 qam9
3ATDMA0000
4ATDMA0000
ClayforthDoyle
  • 8
Message 4 of 9
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
gvca69834ncxv9873254k;fg87dsfd
SFID30574
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID29394
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
ClayforthDoyle
  • 8
Message 5 of 9
02/07/2020 06:13:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 11:31:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 11:31:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 11:30:34criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 11:29:39Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 11:29:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 11:29:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 09:39:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 08:22:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 07:15:44noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 07:15:44ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/06/2020 08:12:10ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/06/2020 14:00:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2020 05:08:5ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 16:24:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:57:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 19:15:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Emily_G
  • 4.45K
  • 188
  • 255
Message 6 of 9
Thank you for the post ClayforthDoyle.
Can we please confirm if you're experiencing these drops through wired and wireless connections?
Have you been in touch with the team or had this rectified since your post?
Let us know, Emily.
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 7 of 9
The downstream power levels, although in spec, look quite high?
gary_dexter
  • 28.72K
  • 1.75K
  • 3.74K
Message 8 of 9
No they're fine
One of the upstreams is at max though
ClayforthDoyle
  • 8
Message 9 of 9
Evening all,
Sorry for the late response, I have not had chance to get on the forums this week.
This is over a wireless connection, the devices I use to access the internet do not have the capability for a wired connection, however I am pretty much smack bang on top of the router.
The issues do seem to have stopped this week fortunately, with the occasional dip in speeds, of which I have always had while using Virgin broadband, annoying they maybe, there the types of drop where a restart of the router generally help.
Kind Regards,
Charlotte.
