sheznet
Message 1 of 5
Frequent inconsistent speed today
I've been having slow response times to various websites, lag and disconnects from several games and some very slow speed test results. I am on m350. I have already tried rebooting my Hub 3. I am unable to post the full network log as it is apparently above the character limit.
13307500001040256 qam25
22587500009.140256 qam16
32667500009.440256 qam17
42747500009.340256 qam18
52827500009.540256 qam19
62907500009.540256 qam20
72987500009.940256 qam21
83067500009.940256 qam22
93147500001040256 qam23
103227500001040256 qam24
113707500001040256 qam26
123787500009.940256 qam27
133867500009.840256 qam28
143947500009.840256 qam29
154027500009.940256 qam30
164107500009.940256 qam31
174187500009.840256 qam32
184267500009.840256 qam33
194347500009.540256 qam34
204427500009.640256 qam35
214507500009.640256 qam36
224587500009.940256 qam37
234667500009.640256 qam38
244747500009.440256 qam39
1Locked40.370
2Locked40.380
3Locked40.950
4Locked40.950
5Locked40.960
6Locked40.940
7Locked40.340
8Locked40.960
9Locked40.330
10Locked40.360
11Locked40.340
12Locked40.350
13Locked40.350
14Locked40.950
15Locked40.900
16Locked40.350
17Locked40.360
18Locked40.950
19Locked40.980
20Locked40.950
21Locked40.950
22Locked40.350
23Locked40.350
24Locked40.900
1326000004.104512032 qam3
2394000004.254512032 qam2
3462000004.154512032 qam1
3ATDMA0000
01/10/2020 17:51:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 17:51:17criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 17:49:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 17:49:57criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 17:47:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 17:47:18criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 17:44:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Frequent inconsistent speed today
Your Downstream Power Levels are on the max or very close to.
You only have 3 Upstream Channels, there should be 4.
And those 3 Channels are at 32 QAM, they should be 64 QAM.
You will need an engineer visit to get everything back to more reasonable levels.
sheznet
Message 3 of 5
Thankyou for the quick reply
Gareth_L
  • 6.96K
  • 424
  • 784
Message 4 of 5
Hello sheznet
Thanks for your post
@MikeRobbo was correct in saying we need to get an engineer booked to come out
I am more than happy to book this in for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
Gareth_L
  • 6.96K
  • 424
  • 784
Message 5 of 5
Hello sheznet
Thanks for passing security
I have booked the first engineer appointment we have available
You can check and reschedule this appointment through your online account if you need to
You can also cancel it if the fault has gone
Can you please let me know how the visit goes
Gareth_L
