paljemer
Message 1 of 5
Frequent drops to below 1Mbps
Hi, I keep getting drops in speed to below 1Mbps, across all devices, both wired and WIFI. For a seemingly random amount of time, usually around an hour or 2. I have tried restarting router, making sure all cables are completely plugged in etc. The diagnosis tool on the virgin media website says that it is not a known issue in my area. Is there anything that I can try (maybe need to try and get an engineer to come look, I'm not sure?)
Thank you
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Frequent drops to below 1Mbps
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
paljemer
Message 3 of 5
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 5
Your >> BQM << will take a while to show any useable trends.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 5
Can you carry out a couple of speed tests at speedtest.net using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected.
Ensure that the Network Interface Card (NIC) drivers are up to date.
Then post the links to the results on here.
