steveyg
  • 11
Frequent dropouts and regular poor speeds on wired connections
I currently seem to be getting 100's of dropouts every day and general poor speeds. Almost all devices are wired, so not WiFi related. When it works, it's fine and I get full speeds. Seems to be no pattern to the drop outs, it can be any time of day or night.
Any ideas?
12587500004.138256 qam16
2138750000640256 qam1
31467500006.340256 qam2
41547500006.140256 qam3
51627500005.540256 qam4
61707500005.340256 qam5
7178750000540256 qam6
8186750000540256 qam7
91947500004.940256 qam8
102027500004.840256 qam9
112107500004.640256 qam10
122187500004.640256 qam11
132267500004.540256 qam12
142347500004.440256 qam13
15242750000438256 qam14
16250750000440256 qam15
172667500004.140256 qam17
182747500003.740256 qam18
192827500003.540256 qam19
202907500003.538256 qam20
212987500003.740256 qam21
223067500003.540256 qam22
233147500003.940256 qam23
243227500003.538256 qam24
1Locked38.942089
2Locked40.32038959507078
3Locked40.3127109841
4Locked40.35082349
5Locked40.35797380
6Locked40.35683585
7Locked40.35628803
8Locked40.35441757
9Locked40.35850488
10Locked40.35513369
11Locked40.34428344
12Locked40.32368286
13Locked40.92087217
14Locked40.33123172
15Locked38.91132150
16Locked40.3849109
17Locked40.330499
18Locked40.336896
19Locked40.960299
20Locked38.6460120
21Locked40.3293112
22Locked40.3200100
23Locked40.321585
24Locked38.931473
1393999983.825512064 qam6
2258000143.725512064 qam8
3326000123.775512064 qam7
4462000173.9512064 qam5
3ATDMA0000
4ATDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Frequent dropouts and regular poor speeds on wired connections
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
Then ...
You have a lot of Post RS Errors, can you reboot your Hub and keep on eye on the error counts over the next couple of days.
steveyg
  • 11
Yes, I'm setting up the monitor now.
The hub 3.0 was restarted about 12 hours ago.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Can you do another reboot on the Hub to see if the Post RS Error counts clear; then post the second part of the Downstream stats in a couple of hours
