Frequent drop outs causing high packet loss
Hi. I've been having connection issues for a few weeks, with dropouts happening fairly frequently. I assumed this was initially just the service being over subscribed but it's happening at hours where I assumed most people are asleep? I've had the super hub changed just over a month ago but problems have persisted. The snapshot above was from yesterdays quality report.
The router is reporting lots of RCS Partial Service and SYNC Timing Synchronization failure.
Any ideas what I can do?
Thanks.
  • 3.54K
  • 570
  • 1.4K
Re: Frequent drop outs causing high packet loss
Your hub has an unstable connection, and is losing synchronisation with the CMTS in the street cabinet.  That could have a range of causes in terms of either noise, error or power level problems, but a fairly common cause is upstream noise, even though you're seeing the problems in terms of downstream.  Your options:
1) Wait for forum staff to pick this up and advise
2) Try VM's call back text service (but if its the offshore crew, they'll probably tell you to reboot your modem and that everything is fixed, but it won't be).
3) This suggestion won't fix it, but may help diagnosis, post here the contents of the tabs titled Downstream and Upstream from your hub's status page.
Hi Andruser.
  • 3.54K
  • 570
  • 1.4K
Your upstream power levels look rather high to me, and that could explain what you're experiencing.  Hang on in here (might take a day or six) for VM staff to advise.
I was lucky enough to get an engineer out today (i was pleasantly surprised). They changed the cable going from the super hub to the wall as they said it was looser, but since having that done, the issue has gotten worse 😅 hoping I can get another engineer to come to look at the issue soon 🤞
  • 4.5K
  • 263
  • 523
Hello petenics
Sorry to hear this is back to as it was
Regarding the engineer.
I have booked you in with the next available appointment.  Please find the appointment time slot via your online account. This can be cancelled and rearranged from there if needed.
Gareth_L
