RileyRa
  • 23
Message 1 of 29
Fluctuating speeds. Low upload!
Been at this property for around 6 days now, and since the internet has been installed/connected i have been getting fluctuating speeds, I am on a 350 down 30up plan, but I have never seen more than a 10 up at the VERY best which is preventing me from doing the things I need to do
(Use it for work etc)
Has my service been throttled. I am on an ethernet connection, not using the Wifi for my computer. The TV is not connected at the moment even though i have the package. I really need some help. Tried calling a couple of times but ever time its been "Please turn everything off and on again and then unplug and reconnect all wires etc etc"
Iv done that many times and it has not made a difference yet. Please can someone help?
Tags (3)
Buffer6
  • 10.4K
  • 92
  • 612
Hero
Message 2 of 29
Re: Fluctuating speeds. Low upload!
RileyRa
  • 23
Message 3 of 29
He did show up, and basically gave us the plug that was needed for the powered wall box, and he seemed to do all the checks but the speeds weren't checked. That im aware of.
RileyRa
  • 23
Message 4 of 29
He gave us the plug and was really helpful and made sure there was internet etc etc, but as far as im aware he didnt check any speeds no.
RileyRa
  • 23
Message 5 of 29
I have read quite a few other posts that seem to have a similar issue etc etc. This is the BQM since i started this thread today, I can also give all the info from the router data etc.
RileyRa
  • 23
Message 6 of 29
RileyRa
  • 23
Message 7 of 29
11390000002.734256 qam1
2147000000335256 qam2
31550000002.534256 qam3
41630000002.735256 qam4
51710000003.735256 qam5
61790000003.234256 qam6
71870000003.734256 qam7
81950000003.735256 qam8
9203000000335256 qam9
10211000000435256 qam10
11219000000435256 qam11
122270000003.235256 qam12
13235000000435256 qam13
142430000003.235256 qam14
152510000003.535256 qam15
162590000004.335256 qam16
172670000002.735256 qam17
182750000002.735256 qam18
19283000000435256 qam19
202910000003.535256 qam20
212990000003.535256 qam21
22307000000435256 qam22
233150000003.235256 qam23
243230000003.935256 qam24
1Locked34.9921640
2Locked35854470
3Locked34.99295360
4Locked358600710
5Locked35605000
6Locked34.91191200
7Locked34.91363980
8Locked35429110
9Locked35.5187510
10Locked35.5182600
11Locked35.5262740
12Locked35.7318560
13Locked35.7290750
14Locked35.5282530
15Locked35.7145240
16Locked35.775400
17Locked35.791580
18Locked35.5117670
19Locked35.777550
20Locked35.5117440
21Locked35.5139940
22Locked35.581820
23Locked35.590710
24Locked35.580010
1394001625.025512064 qam9
2462001455.05512064 qam8
3537000985512064 qam7
4603000295.025512064 qam6
3ATDMA0000
4ATDMA0000
RileyRa
  • 23
Message 8 of 29
10/09/2020 15:41:43noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2020 17:22:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2020 17:22:8Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2020 15:09:8noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2020 11:42:28Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2020 10:28:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2020 09:52:4noticeSW download Successful - Via Config file
07/09/2020 09:49:56noticeSW Download INIT - Via Config file
07/09/2020 09:49:52ErrorDisruption during SW download - Power Failure
07/09/2020 09:47:10noticeSW Download INIT - Via Config file
01/01/1970 00:02:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2020 18:35:2noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2020 18:24:54noticeSW download Successful - Via Config file
20/08/2020 18:19:10noticeSW Download INIT - Via Config file
01/01/1970 00:01:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:29:8criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:29:8Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:29:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Buffer6
  • 10.4K
  • 92
  • 612
Hero
Message 9 of 29
Too many pre-errors and your BQM is showing dropped packets, although it has to populate fully to get a clear picture
I think one of the Forum team needs to look at things from their end
RileyRa
  • 23
Message 10 of 29
Im keeping it running etc, just what i have so far. Would really appreciate if the forum team would have a look. Thanks so much.
