Dmt133
  • 5
Message 1 of 8
Fluctuating speed
I am new customer and have a 200mb download account but keep getting buffering on tv, drop out on video calls and unstable connection.  I have done a reset and speed tests which initially show around 197mbs but quickly drop away to around 40-60mbs and sometimes lower.  Tried to connect to the router setting but it keeps saying the settings password is incorrect on my brand new box and can’t get hold of anyone at virgin?  Any suggestions?
conman33158
  • 726
  • 66
  • 95
Superfast
Message 2 of 8
Re: Fluctuating speed
Have you tried a pinhole reset? Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection. After this use the Admin password at the bottom of the router (Not the WI-FI password) or on the card that came with the router to enter back into the routers settings page.
Dmt133
  • 5
Message 3 of 8
Thanks was trying to avoid having to fully reset the system as I will have to reconnect a million devices to the box again but if that is the only way to get into it.  Problem is also my neighbour says they have similar problems so not sure it will help
conman33158
  • 726
  • 66
  • 95
Superfast
Message 4 of 8
No worries, first things first is getting you access to the router and then we can get you to post some details from it and help diagnosing the problems you are facing. If you have not changed the default wifi password or SSID the devices should connect automatically.
Dmt133
  • 5
Message 5 of 8
Hi I have managed to reset the hub and connected to it via virgin media connect.  What do I do now?
conman33158
  • 726
  • 66
  • 95
Superfast
Message 6 of 8
Can you please upload your router stats
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into you address bar at the top of your browser
For Hubs 2 & 3 - DO NOT LOG IN, just click “Check Router Status”
For Hub 4 - When the page appears LOG IN then click on:
Advanced Settings > Tools > Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again. You can use more than one post for each item if needed.
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screen grabs
conman33158
  • 726
  • 66
  • 95
Superfast
Message 7 of 8
Can you also please set up a Broadband Quality Monitor (BQM) at thinkbroadband.com.
Post a 'Live Link' to your BQM on here asap.
Under your graph you just created Click (Share Live Graph) then click generate.
Copy the text in the Direct Link box and paste it on here
Dmt133
  • 5
Message 8 of 8
11630000000.540256 qam4
21390000001.740256 qam1
31470000001.240256 qam2
41550000000.740256 qam3
51710000000.240256 qam5
6179000000-0.240256 qam6
7187000000-1.940256 qam7
8195000000-0.940256 qam8
9203000000-0.540256 qam9
10211000000-0.740256 qam10
11219000000-0.740256 qam11
12227000000-0.940256 qam12
13235000000-140256 qam13
14243000000-1.240256 qam14
15251000000-1.540256 qam15
16259000000-1.540256 qam16
17267000000-1.740256 qam17
18275000000-240256 qam18
19283000000-2.240256 qam19
20291000000-2.240256 qam20
21299000000-2.240256 qam21
22307000000-2.240256 qam22
23315000000-2.240256 qam23
24323000000-240256 qam24
1Locked40.380
2Locked40.9130
3Locked40.3250
4Locked40.9250
5Locked40.990
6Locked40.9110
7Locked40.390
8Locked40.980
9Locked40.980
10Locked40.960
11Locked40.3100
12Locked40.980
13Locked40.9110
14Locked40.9100
15Locked40.3100
16Locked40.3110
17Locked40.9100
18Locked40.3100
19Locked40.9130
20Locked40.9110
21Locked40.3230
22Locked40.3240
23Locked40.3230
24Locked40.390
