PaulyDo
  • 5
Message 1 of 7
Fluctuating speed and service drop outs
I’m getting wildly fluctuating wifi - from 100mbps to just zero and dropping all together
My job is dependent on working from home now and I’m having to anchor on my phone as the service has become so unreliable and it's making my work almost impossible.
I know WiFi speeds are not guaranteed but the service fluctuates so much and drops to zero so often it’s basically unusable, especially for video/Zoom calls.
Summary:
  • I have a Superhub 3
  • All our connections are wireless/ No Ethernet connections
  • After talking to Virgin
    • I did a scan and it said there were loose connections in the house but they are all ok
    • I used the Virgin media connect app to scan the house and all good
    • Virgin then sent me a new Hub box but the issue is still there
  • I’ve been monitoring with Oolka speedtest on various devices and can see that when I have 0mg on my Macbook I’m still getting 20mg on my iphone next to it
  • When I lose connection on some devices there is still a connection on others
I have downloaded my Network logs and can see there are a lot of Errors/warnings/Criticals - could that be the cause?
Have listed them below followed by the Downstream and Upstream logs (will have to separate messages)
Does anyone have any idea?
Network Log:
20/05/2020 19:59:43ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 12:07:10ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 08:18:09Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 04:14:40ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 01:29:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 12:29:40ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 06:31:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2020 11:02:09criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2020 09:07:23Warning!TEK Invalid - Invalid Key Sequence Number;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2020 10:02:06Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/05/2020 11:37:04criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/05/2020 05:53:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 16:59:42ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 16:41:22ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 15:34:24ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 15:23:07ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 14:41:53ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 13:43:07ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 13:23:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/05/2020 23:02:34
Error
PaulyDo
  • 5
Message 2 of 7
Re: Fluctuating speed and service drop outs
1186750000-3.238256 qam7
2194750000-3.538256 qam8
3202750000-3.538256 qam9
4210750000-3.938256 qam10
5218750000-4.233256 qam11
6226750000-4.234256 qam12
7234750000-4.238256 qam13
8242750000-438256 qam14
9250750000-3.938256 qam15
10258750000-3.738256 qam16
11266750000-3.538256 qam17
12274750000-3.738256 qam18
13282750000-3.238256 qam19
14290750000-2.938256 qam20
15298750000-2.738256 qam21
16306750000-2.538256 qam22
17314750000-2.540256 qam23
18322750000-2.538256 qam24
19402750000-2.740256 qam25
20410750000-2.538256 qam26
21418750000-2.540256 qam27
22426750000-2.538256 qam28
23434750000-2.740256 qam29
24442750000-2.738256 qam30
ChannelLocked StatusRxMER (dB)Pre RS Errors
Post RS Errors
1Locked38.9242528580017
2Locked38.91120471051
3Locked38.676474560
4Locked38.9999061502
5Locked33.3147943056159
6Locked34.328335823310
7Locked38.940575111
8Locked38.640416460
9Locked38.924944573
10Locked38.91825552
11Locked38.91850229
12Locked38.91375155
13Locked38.91082225
14Locked38.9881218
15Locked38.9776517
16Locked38.9727721
17Locked40.3740124
18Locked38.9647818
19Locked40.338954
20Locked38.973889301
21Locked40.339379
22Locked38.9380511
23Locked40.341445
24Locked38.6427710
PaulyDo
  • 5
Message 3 of 7
Upstream
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
1603000545.025512064 qam37
2394000104.925512064 qam40
3461999375.025512064 qam39
4536999415.05512064 qam38
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0000
gary_dexter
  • 29.22K
  • 1.79K
  • 3.83K
Message 4 of 7
Without a wired device it’s difficult to ascertain actual speeds.
However your hub stats are all over the place there and you might need an engineer visit
Roger_Gooner
  • 6.41K
  • 468
  • 1.11K
Hero
Message 5 of 7
Your upstream levels are on the high side and you have Post RS Errors on every downstream channel. As you've checked your coaxial cables for tightness and you've had a hub swap I suspect an network problem and a VM tech should be sent round.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
PaulyDo
  • 5
Message 6 of 7
Thanks for that -
Confirmed my suspicions that it's a network issue - going to book an Engineer visit now
Cheers
PaulyDo
  • 5
Message 7 of 7
Thanks for looking at this - will book a visit
cheers
