jtjnr2
Fluctuating Broadband speed and intermittent disconnection
Hi, I recently switched from Sky to Virgin and took advantage of the 500Mbps offer. Recently, though, my speed of service seems to change randomly throughout the day reaching 135Mbps down to 11 and once down to 0.38. Also being occasionally disconnected. Like everyone else working from home and been chucked out of a number of conference calls or lost audio/video mid way.
Anyone have any ideas - I have rebooted and reset the hub more than once. I am disappointed with the service to be honest and starting to regret the switch, a consistent, reliable broadband is vital at these times.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Fluctuating Broadband speed and intermittent disconnection
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
dinth
  • 48
  • 45
Dialled in
Are you using any apps heavily utilizing UDP connections (BBC iPlayer, Skype/Teams/other videoconferencing, VPN, torrents, VoIP)?
Check this https://community.virginmedia.com/t5/Speed/UDP-issues-on-SuperHub3-collective-thread/m-p/4469073#M24...
