  • 20
Message 1 of 7
Fine one minute then nothing then fine again!
So my Internet keeps dropping randomly during the day. I have been working at home fine for just over 2 weeks with no issues. The all of a sudden this week I keep getting drop outs and then speeds of 0.2! Then it would slowly come back online for a little while only to repeat the issue!
I've spoken to tech support who saw an error on the router and said it needed changing but they had to send an engineer out. He came and reported no issues saying it must be my setup and that something must be sucking all the bandwidth. Well I have been monitoring all devices since and nothing is ramping up useage at all but I still get drop outs!! Nothing new has been added or night has changed so I can only see that there must be a virgin issue!
I need this in this difficult times to be able to carry on working.
Can anyone help please?
Simon
  • 71
  • 8
  • 14
Message 2 of 7
Re: Fine one minute then nothing then fine again!
Hi Simon.
Kindly pop me private message with your account number and area code and ill have a look at the line for you.
Cheers
Steven
Tech working from home..
  • 20
Message 3 of 7
Steven.
PM sent 👍
  • 20
Message 4 of 7
This is the log from this morning.
No idea if its of any help!
12/04/2020 09:33:22noticeLAN login Success;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:29:27Warning!RCS Partial Service;CM-MAC=***********;CMTS-MAC=*********-QOS=1.1;CM-VER=3.0;
12/04/2020 09:29:26criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********;CMTS-MAC=***********-QOS=1.1;CM-VER=3.0;
12/04/2020 09:29:14Warning!RCS Partial Service;CM-MAC=***********;CMTS-MAC=***********-QOS=1.1;CM-VER=3.0;
12/04/2020 09:29:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********;CMTS-MAC=***********CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:28:49Warning!RCS Partial Service;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:28:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:28:43Warning!RCS Partial Service;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:28:43criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:27:12Warning!RCS Partial Service;CM-MAC=***********;CMTS-MAC=***********CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:26:59criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:26:41Warning!RCS Partial Service;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:26:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:21:34Warning!RCS Partial Service;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:21:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:21:13Warning!RCS Partial Service;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:21:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:19:57Warning!RCS Partial Service;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:19:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 09:16:42Warning!RCS Partial Service;CM-MAC=***********;CMTS-MAC=***********;CM-QOS=1.1;CM-VER=3.0;
  • 15
Message 5 of 7
Hi Simon can you post if you get a fix for this problem please? It looks like exactly the same issue we have.
  • 20
Message 6 of 7
Will do
  • 6
Message 7 of 7
Have exactly the same problem as you. One minute I'm getting 200+mbps then below 40 then back up to near 200. Today I've lost connection twice and had to restart the hub. I'm in area 06
