Message 1 of 10
Fibre 350 worth it?
Recently started on the Fibre 350 plan. Tested my speed (next to router) and I'm only getting between 55 and 80 mbps. Went on the Virgin website to try and find someone to contact about this but doesn't seem possible to do that. Presumably BT fibre product is a better bet as it doesn't rely on cable technology? Maybe it would also be possible to get through to customer service with them.
  • 20.96K
  • 1.14K
  • 2.7K
Message 2 of 10
Re: Fibre 350 worth it?
You need to speedtest when wired direct to the hub.
Wireless speeds and connectivity aren’t guaranteed
Message 3 of 10
Thanks. Don't have the equipment for that though. Virgin say speeds only up to 30% slower if wireless.
  • 30.41K
  • 1.52K
  • 5.28K
Message 4 of 10
where do VM stay that. Thay say any speed garantee is only for wired connections.
No one can control wireless.
And BT is worse as they still use twisted copper. Coax is better.
Best: Fiber --> Coax --> Twisted copper : Worst
  • 3.54K
  • 569
  • 1.4K
Message 5 of 10
Not for reliability, nor for latency.
  • 20.96K
  • 1.14K
  • 2.7K
Message 6 of 10
Where have VM ever quoted WiFi speeds only being 30% slower?
Message 7 of 10
Hi, here's the link to the 30% slower point, https://my.virginmedia.com/discover/broadband/your-broadband/connecting/connection-type
Thanks for the responses
  • 3.54K
  • 569
  • 1.4K
Message 8 of 10
Those speeds are absolutely typical of a wireless device connecting on 2.4 GHz.  Your hub has two wireless bands, one at 2.4 GHz, one at 5 GHz.  The 5 GHz is far superior, but the way the hub is setup is that both share the same network name.  Whilst simple, this often causes problems.  I'll assume your device does support 5 GHz - other than a few cheap wireless cards, old laptops, and many Internet or Tat devices, virtually all devices do support 5 GHz.
You will need to go into the hub's admin page, dig in the settings, and rename the 5 GHz network.  Either just add a 5 on the end of it, or give it a funky name like LAN of Confusion, or whatever else takes your fancy.  You can change the wifi password to something easy to remember (but do that for both 2.4 GHz and 5 GHz bands to make your life easy).  Whilst you're there, turn off Guest wifi if you don't use it, and in wireless settings turn off automatic optimisation, and set 5 GHz channel width to 20/40/80.  Each time you change something, click on the Save or Apply button at the bottom of that page.
When you come out of the hub settings, get your devices to connect to the 5 GHz wireless band that now has a new name, and I suspect you'll find that speeds have improved dramatically.   Don't worry about screwing up the wireless settings - if the worst came to the worst (eg you forgot your new wifi password, or devices wouldn't connect at all) then you just reset the hub by using the pinhole reset button on the back - but it shouldn't come to that.
If that doesn't sort things out, then it may be a faulty broadband line, but we can look at that if need be.
  • 20.96K
  • 1.14K
  • 2.7K
Message 9 of 10
That’s an archived page and refers to the old Wireless N 2.4Ghz Superhub.
Either way, you need to read the updated current speed guarantee where it says wireless speeds aren’t part of the Speed Guarantee.
Message 10 of 10
Thanks, that worked
