BIGTONE1
  • 18
Message 1 of 5
Faulty Hub?
My 150Mbs service is continually coming in at 20-30Mbs download and 5Mbs upload hard wired direct into the hub3.I spoke to VM customer services on the phone for 50 minutes and still not resolved. Done a hard reset still the same.  Used another cable direct from the laptop to the hub. Still the same result. Used another laptop still the same. If I use either of my iPads on wi Fi it comes in at 111Mbs +
Customer services checked the equipment and said no fault is showing?
I was supposed to have a scheduled call today from a “virtual technician “…..no call.  I guess they went down the pub!  So in conclusion I think my VM hub is shot.
Where do I go from here?
Andrew-G
  • 9.53K
  • 1.54K
  • 4.56K
Message 2 of 5
Re: Faulty Hub?
I'm at a loss as to why wired speeds are so much lower than wifi, but as even 111 is lower than 150, I'd start off by asking if you can connect to the hub by clicking on this link http://192.168.0.1/  That should pull up the log in page for the hub.  But don't log in, just click on the link "Check router status"  That'll bring up a window with five tabs.  Open the Downstream tab.  Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as TEXT not screenshots.  Post that, do the same for the Upstream and Network log.  You'll get an error message when you post the Network log, just click on "post" a second time.  Then we can check for any obvious problems with power, noise or error counts.
An alternative thought is that if you're still on 150 Mbps, that's a legacy speed that hasn't been offered for about five years, and probably means you're paying an uncompetitive price?  If so, you could kill two birds with one stone, by phoning up to cancel, and you tell them "the value is poor - speeds are too low, and the price is too high - I'll stay if you can sort both".  The retentions agents are used to dealing with technical faults and can schedule a technician.  Combine that with the methods in the link below, see how you get on:
https://community.virginmedia.com/t5/Networking-and-WiFi/can-you-downgrade-package-without-using-the...
BIGTONE1
  • 18
Message 3 of 5
Re: Faulty Hub?
Thanks for your comprehensive answer Andrew. It just so happens I had a phone call this afternoon from VM and a VM engineer is schedule to arrive within the next 3 hours. I have noted what you suggest and will use that in the future if I have issues.
once again many thanks.
Tone.
BIGTONE1
  • 18
Message 4 of 5
Re: Faulty Hub?
Just an update.
Engineer came and tested the Hub and my Cat 6 cable.  All good.  It would appear that one of my laptops is giving up the ghost. I shall take it in and see if it can be saved otherwise it’s a new lappie.
Travis_M
  • 2.92K
  • 100
  • 214
Message 5 of 5
Re: Faulty Hub?
Hi @BIGTONE1
Let me know how you get on, my apologies for the previous inconvenience.
Travis_M
