Got a few of them myself, I ended up just pulling the phone line out of the hub as I never use it anyway. Absolute pests, got 7 calls on the same day from 7 different numbers, no phone line now so no more calls but that wouldn't suit everyone that uses their home phone line all the time.
What speed do you get on https://speedtest.samknows.com/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps capable Ethernet network card?
- Make sure the cable is Cat 5e or better
- Make sure your PC/laptop has a 1Gbps or better network card
- Make sure Hub is in router mode
- Disconnect all other Ethernet cables when running the test
