awr1946
  • 51
FaceTime keeps crashing
We have 100mbps but it’s running at about 50mbps.  FaceTime keeps crashing, when our daughter contacts us the video is clear but we we do the same the video is blurry.
We have to keep reconnecting but the connection only lasts a little while each time.
Any ideas?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: FaceTime keeps crashing
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
awr1946
  • 51
Hi Mike,
Thanks for your answer but unfortunately I don’t have what’s required to do what you suggest.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
