FTTP Request
HunterD
Hi there,
Just got my new Hub 4 and loving the download, but I'm wondering if it's possible to request FTTP to my house as other houses in my street and area have FTTP and I know the fibre goes to the street pits, just not into my house.
I'd love to make full use of my fibre speed with download and upload speeds to match as I stream on twitch and stream allot of content to my devices too and run IT support from my home for charity. 🙂
1 REPLY 1
Roger_Gooner
You are on the legacy HFC network and can only get coaxial cable to your house. The fibre part of the network goes to an optical node from where coaxial cables are installed to homes via distribution cabinets.
In the long term VM will be replacing all the coaxial cables with fibre, and it's expected that this will happen from about 2030.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
