biggee13
  • 7
Message 1 of 11
Extremely slow speed
For the last 3 weeks the maximum speed I have been receiving is 30mbps when I am on a 350mbps package. I restart my router on a daily basis and nothing has changed.  I have tried contacting Virgin with no luck.
Is anyone else experiencing this in the N19 area?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 11
Re: Extremely slow speed
How are you connecting your device, Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
biggee13
  • 7
Message 3 of 11
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 11
@biggee13 wrote:
My BQM
That is a speed test not BQM.
biggee13
  • 7
Message 5 of 11
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 11
Can you go into the Hub settings and uncheck IPv4 Firewall Protection.
Can you also post your Hub data please.
biggee13
  • 7
Message 7 of 11
13870000008.638256 qam32
22030000009.338256 qam9
3211000000938256 qam10
4219000000938256 qam11
52270000009.138256 qam12
62350000008.838256 qam13
72430000008.538256 qam14
82510000008.438256 qam15
92590000008.338256 qam16
102670000008.138256 qam17
112750000007.938256 qam18
122830000007.638256 qam19
132910000007.438256 qam20
142990000007.138256 qam21
15307000000738256 qam22
163150000007.538256 qam23
17323000000838256 qam24
183310000008.138256 qam25
19339000000838256 qam26
203470000008.338256 qam27
213550000008.438256 qam28
223630000008.638256 qam29
233710000008.538256 qam30
243790000008.638256 qam31
1Locked38.6160
2Locked38.6340
3Locked38.6320
4Locked38.6440
5Locked38.6670
6Locked38.9500
7Locked38.6290
8Locked38.9460
9Locked38.6450
10Locked38.9220
11Locked38.9360
12Locked38.6540
13Locked38.6780
14Locked38.6600
15Locked38.6340
16Locked38.9220
17Locked38.6230
18Locked38.9250
19Locked38.6450
20Locked38.9530
21Locked38.6550
22Locked38.9370
23Locked38.6260
24Locked38.9220
Tags (1)
biggee13
  • 7
Message 8 of 11
1603002694.4512064 qam1
2394000244.325512064 qam4
3462000584.35512064 qam3
4536997764.35512064 qam2
3ATDMA0000
4ATDMA0000
Tags (1)
biggee13
  • 7
Message 9 of 11
26/08/2020 08:31:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/08/2020 00:11:48ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/08/2020 23:41:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/08/2020 23:40:44criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/08/2020 23:35:56Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/08/2020 23:35:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/08/2020 23:35:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/08/2020 23:35:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/08/2020 23:35:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/08/2020 04:40:44ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;24/08/2020 21:18:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;24/08/2020 20:33:27ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;23/08/2020 12:23:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/08/2020 13:05:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/08/2020 13:05:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/08/2020 13:05:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (1)
Gareth_L
  • 6.17K
  • 379
  • 665
Message 10 of 11
Hello biggee13
Sorry you have had to post on our forums regarding the recent slow speeds
Can I please how things are looking now
I would also like to help get this resolved if you still need help
Gareth_L
