on 24-09-2021 00:02
I'm getting really slow speed from my M500 on hub 3. I get downloads of around 5mbps and uploads of 11mbps. This is on wired connection. Also I see the internet light green and blinking continuously. I tried rebooting several times but no avail.
Please help.
on 24-09-2021 15:44
on 25-09-2021 10:06
I did check for known faults and it all shows nothing wrong. I have now changed hub3 to modem mode and connected it to my eero 6 but no difference in speed. Still getting pathetic 10 Mbps. Last night was even worse at 1mbps. At times I'm unable to use YouTube!
on 25-09-2021 13:29
on 26-09-2021 17:32
1 | 387000000 | 4.6 | 38 | 256 qam | 32 |
1 | Locked | 38.9 | 387 | 3185 |
1 | 53699659 | 52.3 | 5120 | 64 qam | 6 |
1 | ATDMA | 0 | 0 | 0 | 0 |
26/09/2021 15:51:47 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/09/2021 11:08:7 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/09/2021 09:03:1 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/09/2021 20:04:7 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:47:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:45:53 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:45:44 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:45:14 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:44:58 | Warning! | MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:44:58 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:38:53 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:38:50 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:38:44 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:36:58 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 10:36:53 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 01:22:56 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/09/2021 23:28:59 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/09/2021 23:19:50 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/09/2021 23:17:48 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/09/2021 23:17:44 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
Broadband quality monitor:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/60718edad13c8043f43bb6f67e5fb07e0b834a0c
on 27-09-2021 11:19
Also, adding configuration
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt053-b.cm |
SFID | 16272 |
Max Traffic Rate | 575000000 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 16271 |
Max Traffic Rate | 38520000 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
on 27-09-2021 11:25
@athlon2005 OK that connection has just failed completely. It's probably worth trying a pinhole reset of the Hub (if and when you call up for an engineer visit, they'll probably insist on you doing this anyway), hold the reset button in for a good 60 seconds, let the hub reboot itself (don't reboot it yourself afterwards). Also just check that all the cables are nice and tight.
I don't actually have too much hope that this will resolve anything and you'll end up having to get an engineer visit. You could try calling in or waiting for a member of the forum team to get to this thread and offer to contact you directly.
on 27-09-2021 11:44
Thanks @jem101. How did you figure out the connection failed from the logs? Also, does a failed connection lead to slow internet or complete loss of internet - because I have slow speeds.
on 29-09-2021 12:47
Good afternoon @athlon2005
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you have had some issues with your services.
I have managed to locate your account from here, I can see that you have spoken with our technical support team who have been able to book an engineer visit for you.
If we are able to assist you further then please do let us know.
Kind regards,
Zak_M
