Imconfusednow
Message 1 of 8
Extremely low upload speed
Hi, I've had exceptionally slow upload speeds since this morning.
Speed test says it's 0.01mbs up whilst 100mbs down.
I've tried resetting the router, disabling firewall, running diagnostics here and calling virgin.
Haven't really received anything helpful yet. Seems the service is meant to be good here in ng2. It's a wired connection.
Any ideas please.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Extremely low upload speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Imconfusednow
Message 3 of 8
Hi thanks for your response. Having to post on my phone on 4g because the speed is too slow to login on the broadband. So things might take a bit.
I've done all the top steps. I shall endeavour to get the information posted asap.
HUp66
  • 35
  • 5
Message 4 of 8
Been having same issue for over a week and they say it is SNR issue but I don't believe it (even though there is an SNR issue in my area.)
Where it shows full packet loss my broadband is fine but roughly from 6.45pm until 6.45am upload is useless, which makes using the internet basically useless. As you can see the issue started again this evening at 6.45 (ish)
My BQM
Imconfusednow
Message 5 of 8
So router status:
status
Downstream channel: 33100000    locked
Upstream channel: 46200484         locked
Provisioning status: online
downstream
Refresh data
Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
1    331000000    7.9    40    256 qam    25
2    203000000    8.3    40    256 qam    9
3    211000000    8.3    40    256 qam    10
4    219000000    8.1    40    256 qam    11
5    227000000    8    40    256 qam    12
6    235000000    7.6    40    256 qam    13
7    243000000    7.4    40    256 qam    14
8    251000000    7.5    40    256 qam    15
9    259000000    7.5    40    256 qam    16
10    267000000    7.5    40    256 qam    17
11    275000000    7.8    40    256 qam    18
12    283000000    7.5    40    256 qam    19
13    291000000    7.6    40    256 qam    20
14    299000000    7.5    40    256 qam    21
15    307000000    7.6    40    256 qam    22
16    315000000    7.8    40    256 qam    23
17    323000000    7.6    40    256 qam    24
18    371000000    7.9    40    256 qam    26
19    379000000    7.8    40    256 qam    27
20    387000000    7.9    40    256 qam    28
21    395000000    8    40    256 qam    29
22    403000000    8.3    40    256 qam    30
23    411000000    8.4    40    256 qam    31
24    419000000    8.3    40    256 qam    32
Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
1    Locked    40.9    1    0
2    Locked    40.3    5    0
3    Locked    40.3    5    0
4    Locked    40.9    4    0
5    Locked    40.9    7    0
6    Locked    40.3    7    0
7    Locked    40.9    0    0
8    Locked    40.9    5    0
9    Locked    40.9    4    0
10    Locked    40.9    6    0
11    Locked    40.3    6    0
12    Locked    40.9    7    0
13    Locked    40.9    5    0
14    Locked    40.9    6    0
15    Locked    40.9    4    0
16    Locked    40.9    4    0
17    Locked    40.9    0    0
18    Locked    40.9    1    0
19    Locked    40.9    6    0
20    Locked    40.9    13    0
21    Locked    40.9    5    0
22    Locked    40.9    7    0
23    Locked    40.9    13    0
24    Locked    40.9    6    0
upstream
Channel    Frequency (Hz)    Power (dBmV)    Symbol Rate (ksps)    Modulation    Channel ID
1    46200484    3.725    5120    16 qam    1
2    32599378    3.725    5120    16 qam    3
3    25799937    3.775    5120    16 qam    4
4    39401525    3.725    5120    16 qam    2
Channel    Channel Type    T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
1    ATDMA    0    0    0    0
2    ATDMA    0    0    0    0
3    ATDMA    0    0    0    0
4    ATDMA    0    0    0    0
Configuration
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsl10016u-b.cm
SFID    177866
Max Traffic Rate    117000047
Max Traffic Burst    42600
Min Traffic Rate    0
Primary Upstream Service Flow
SFID    177865
Max Traffic Rate    10500047
Max Traffic Burst    16320
Min Traffic Rate    0
Max Concatenated Burst    16320
Scheduling Type    BestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 8
All four of your Upstream Channels are at 16 QAM, they should be at 64 QAM.
You can try and get an engineer to put them right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
upstream
Imconfusednow
Message 7 of 8
Beth_G
  • 3.46K
  • 215
  • 348
Message 8 of 8
Hi Imconfusednow,
Welcome to the Community Forums 🙂
We're really sorry for our delayed response and for the speed issues you've been experiencing recently.
I've been able to find your account and can see you were able to speak with our faults team concerning the issue. It looks like there's an SNR issue in your area, which is actually due to be fixed at around 6pm today, so please let me know how your services are after the given fix date.
Many thanks,
Beth
