Alex0822
Just joined
Every evening at 5 - 8pm my wifi drops to 1mbps download speed, and 0.1mbps upload speed
its been like this for weeks, would be nice to be able to go on the internet in the evenings again
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Every evening at 5 - 8pm my wifi drops to 1mbps download speed, and 0.1mbps upload speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Martin_N
  • 5.55K
  • 232
  • 318
Hi Alex0822,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the broadband issue you're having.
I have taken a look on our side and from what I can see you do require an engineer visit.
I will private message you to get some details to assist with this.
^Martin
